Stainless steel brake lines Question
Old Oct 13, 2021 | 09:23 AM
KRPTONT's Avatar
KRPTONT
Default Stainless steel brake lines Question
So I have upgraded my brakes to C6 Z06 brakes and when putting on the brake lines there is a nipple from the hard line that goes into the stainless steel brake lines. But the C6 lines won’t work. So I am assuming I just use C5 stainless steel brake lines?? Thank you in advance
Old Oct 13, 2021 | 03:47 PM
avigar's Avatar
avigar
I believe that there's a difference in brake line connectors. I recently changed mine to C5 specific stainless steel brake lines for my '04.
Old Oct 14, 2021 | 03:38 PM
jjc508520's Avatar
jjc508520
Same thing happened to me! I wound up reusing my C5 SS lines - which were almost identical in length. My story (with pics of the brake lines) here...
C6 Z06 brake upgrade notes - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Oct 14, 2021 | 04:25 PM
ThomasR's Avatar
ThomasR
From your picture it appears to me that the left is a bubble flare (metric) and the right is a double flare (SAE). You could use the old hoses, or change the nut and re flare the hard line to use the new hoses.
Old Oct 14, 2021 | 07:22 PM
Moved to C5 Tech.
To Stainless steel brake lines Question
