Throttle problems
Old Oct 13, 2021 | 07:45 PM
DeeLaja's Avatar
DeeLaja
Default Throttle problems
Hey guys any help is dearly appreciated I’m getting p1120 p1220 p1516 I know it’s a throttle problem just wondering where should I start thanks a lot to anyone willing to help
Old Oct 13, 2021 | 08:48 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I would look at the TPS wiring first…remove the connector and check for oxidation and pin fitment…a scan tool or better yet a scope where you can graph the 2 TPS voltages would help in the diagnosis !!
Old Oct 13, 2021 | 09:02 PM
DeeLaja's Avatar
DeeLaja
I check all is good I’m thinking because I’m in Michigan we had a lot of rain and a medium flood water might got in the TAC module
Old Oct 13, 2021 | 09:14 PM
C5 Diag's Avatar
C5 Diag
That would have been an important thing to mention in your first post…you may have a water intrusion issue !!
Old Oct 13, 2021 | 10:08 PM
DeeLaja's Avatar
DeeLaja
would that be water in the TAC Module I’ll check may be order a new one thanks so would it throw these codes
Old Oct 25, 2021 | 05:51 PM
Intimidatorc5's Avatar
Intimidatorc5
4th Gear
Is there any update to your issue? i am having the exact same problem codes with my C5.
Old Oct 25, 2021 | 06:25 PM
DeeLaja's Avatar
DeeLaja
TAC module was bad I change the sensor first but TAC Module was wacked out
Old Sep 18, 2022 | 09:37 PM
kz0925's Avatar
kz0925
Where did you get your TAC module from? and did it fully resolve your issue? I'm experiencing the same problem with my c5 ;/
To Throttle problems
