Engine movement
Old Dec 22, 2002 | 08:00 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Default Engine movement
So how much engine lateral movement do you get under turning, acceleration?
I am having header clearance issues. I have checked the motor mounts and everything looks ok. :crazy: I also have removed 3/16" of material on the cross member where the header is making contact. When making a hard left turn you can still hear it :cuss Should I continue to remove material or??
Old Dec 22, 2002 | 09:25 PM
davidfarmer's Avatar
davidfarmer
Default Re: Engine movement (Dugmole)
VBP has poly motor mounts that will help, as the OEM mounts do move quite a bit. On our race car, the harmonic balancer would actually move forward enough to hit the power steering, slowly carving a hole in it, during braking.
Dave
Old Dec 22, 2002 | 09:26 PM
davidfarmer
btw, if you are clearancing the steel reinforcements, carve away. I wouldn't do too much trimming of the aluminum crossmember.
Old Dec 23, 2002 | 09:42 AM
Dugmole's Avatar
Dugmole
Default Re: Engine movement (davidfarmer)
Thanks. Yes it is the aluyminum cross member. The guys at TTS said due to different castings that some vehicles will have clearance issues. I will try the alternate mounts. Better than carving!
To Engine movement
