1998 Corvette C5 ABS Module
Old Oct 14, 2021 | 09:00 AM
Silverfox 69's Avatar
Silverfox 69
8th Gear
Default 1998 Corvette C5 ABS Module
Hello Everyone
I'm new to this forum so forgive me if I'm not easy to understand.
Originaly from the UK, now in Dubai UAE.
I recently bought a 1998 C5. The deal was that the previous owner would buy and replace the faulty ABS module.
This has not proved easy, so I'm taking the matter into my own hands.
Simply put, where can I get the module to buy or be repaired ?
Alternatively is the module shared by any other GM model that I can try to find here in the UAE ???
Any assistance would be very appresiated.
Many thanks Peter (Aka Silverfox 69)
Old Oct 14, 2021 | 11:41 AM
Moved to C5 Tech.
Old Oct 14, 2021 | 02:23 PM
RedRiderZR1's Avatar
RedRiderZR1
Originally Posted by Silverfox 69
Hello Everyone
Peter,
Since you have a 1998 there are two possible mounting locations for your module. Is the module located at the rear of the car or under the hood?
There are 2 different modules built for that year. Non active handling and active handling units. They are designated with a M or a V on the top of the module. The M is non active handling and V is the active handling unit. In order to know which one you need you would have to look and post up which model you have ( M or V ).
As for other units, there are other units from other cars that look the same but the internal programming is different. So you would need a ebcm from a corvette.
Old Oct 14, 2021 | 04:03 PM
SilverC54me's Avatar
SilverC54me
Just a note, all of the rear mount EBCMs do not have active handling. The cars with the front mount have the option of having active handling.
If a rear mount, you could use one from a 1997 or early run 1998. If a front mount it could come from a late run 1998 to 2000 depending on if it is active handling or just traction control.
Then there is what codes are in the system for the EBCM? Some of the codes are for components external to the EBCM.
Here is a YouTube video on how to read the codes,
Gary
Old Oct 15, 2021 | 05:00 AM
Silverfox 69
8th Gear
Default 98 c5
Originally Posted by RedRiderZR1
Peter,
Thank you for your very valuable information. I have asked the workshop to answer the question.
Old Oct 15, 2021 | 05:05 AM
Silverfox 69
8th Gear
Hello Gary.
I am learning as I go along :-)
As with the other great message I was sent, I'm passing all of this to the workshop working on my car.
As you can imagine there are very few older Corvettes here in the UAE. Knowledge and parts are very rare.
Many thanks.
Old Oct 17, 2021 | 04:57 AM
Silverfox 69
8th Gear
Hello Gents
Information from the workshop working on my car.
They say the module is rear mounted and the harness was burnt by the exhaust.
The fault is no communication from the module.
What do you suggest I do next?
Do I have any chance of getting a used or repairing the module / harness ?
Many thanks
Old Oct 17, 2021 | 09:23 AM
Silverfox 69
8th Gear
Apparently the harness has been repaired. :-)
Old Oct 17, 2021 | 10:44 AM
666lisa's Avatar
666lisa
Did that fix the problem???
Old Oct 17, 2021 | 10:46 AM
Silverfox 69
8th Gear
Unfortunately not ! They say the module is fried :-(
Old Oct 17, 2021 | 10:48 AM
Silverfox 69
8th Gear
I really need a used part, or repair, whichever is the most economical, or possible ???
Old Oct 17, 2021 | 10:52 AM
666lisa's Avatar
666lisa
Friend ran into this problem 1998. There is only used ones and it's not guarantee. I think they go for around 1000.00 used.
Old Oct 17, 2021 | 10:58 AM
Silverfox 69
8th Gear
If anyone knows of one, it would be a great help
Thanks for info :-)
To 1998 Corvette C5 ABS Module
