constant door chime
Old Oct 14, 2021 | 12:38 PM
Lancer11's Avatar
Lancer11
Cruising
Default constant door chime
Any ideas on why the door chime would continuosly go off even when the key is in or out of the ignition and the door is shut. Also, the battery is dead. Had to disconnect negative terminal to stop the annoying sound.
Old Oct 14, 2021 | 02:42 PM
mmartinez's Avatar
mmartinez
Most likely the contacts in the Ignition switch that detect that the key has been inserted have failed, you will probably have to remove the Ignition switch.
Old Oct 14, 2021 | 03:47 PM
Lancer11's Avatar
Lancer11
Cruising
yeah...that's what I figured...thought maybe it was a secret c5 thing/warning....
To constant door chime
