Clutch feels like it’s always Disengaged
Old Oct 15, 2021 | 03:02 PM
24041110f's Avatar
24041110f
5th Gear
Default Clutch feels like it’s always Disengaged
I was at the track racing quarter mile took off went through first gear push the clutch and shifted to second let the clutch out and there was nothing there when Car is off I can shift through the gears without stepping on the clutch when car is running I put it in first gear let out the clutch car doesn’t move no leaks anywhere I bled my slave cylinder still nothing One up on a lift I put it in gear and the back tires lock so the transmission and rear end are working is it a faulty slave cylinder?
Old Oct 15, 2021 | 05:06 PM
feeder82's Avatar
feeder82
No, more likely you broke the input shaft
Old Oct 15, 2021 | 08:45 PM
24041110f's Avatar
24041110f
5th Gear
when I step on the clutch it stays stuck down I can pull it up but still it’s still disengaged Tried to bleed it but still the same thing
Old Oct 15, 2021 | 08:47 PM
666lisa's Avatar
666lisa
What do you mean (back tires lock)???
Old Oct 16, 2021 | 05:48 AM
24041110f's Avatar
24041110f
5th Gear
If I put it in first gear go around to the back of the car and go to spin the passenger tire it’s in gear so the transmission is engaging but the clutch is not
To Clutch feels like it’s always Disengaged
