ECKLER'S SHORTENED FACTORY SHIFTER ?
Old Dec 22, 2002 | 09:51 PM
Oldvetter's Avatar
Oldvetter
Default ECKLER'S SHORTENED FACTORY SHIFTER ?
Any one try this shifter? How is it ?
I would appreciate a little shorter throw, but not at expense of great effort and heat and noise.
Old Dec 22, 2002 | 10:06 PM
jschindler's Avatar
jschindler
Default Re: ECKLER'S SHORTENED FACTORY SHIFTER ? (Oldvetter)
Have you got a link to it? I'm not familiar with (I'll do a search when I'm done here). I have a modified stock shifter I did myself. I had a Ripper. I find the modified shifter a great compromise. The Ripper was still more precise, but the modified stock shifter is much nicer than stock, and easier to use in city traffic.
Old Dec 23, 2002 | 11:15 AM
MySea6's Avatar
MySea6
Default Re: ECKLER'S SHORTENED FACTORY SHIFTER ? (jschindler)
Looks like they just cut it down from the top and left the isolator intact.
I suggest, if this is what you want, go the way jschindler did. With the instructions from chuckster. Far more solid and it's a (semi) free mod. :thumbs:
I can't seem to find the link for the instructions by chuckster, but I know it's here somewhere...........
Old Dec 23, 2002 | 11:29 AM
benelliwang's Avatar
benelliwang
This link will show you all three versions.
http://benelliwang.badassride.com/Shifter/index.html
Old Dec 23, 2002 | 01:31 PM
Guest
Guest
Posts: n/a
Default Re: ECKLER'S SHORTENED FACTORY SHIFTER ? (benelliwang)
All,
Its actually the exact same thing as Corvettes Concepts shifter. I have it instaleed in mine. Its exactly the same feel as stock but shorter. It is not stiff like most of the after market products. I think it works very well. It also uses all of the stock mounting hardware.
Matt
To ECKLER'S SHORTENED FACTORY SHIFTER ?
