ABS Traction control and Ride control warning!
Old Oct 17, 2021 | 11:05 AM
Fastchef's Avatar
Fastchef
3rd Gear
Default ABS Traction control and Ride control warning!
I have a 98 Corvette and recently my crank pulley was cracked and it kept breaking belts. The second belt broke and all of my warning lights came on. I can't see any obvious wiring problem, but the shredded belt must have hit something. Any Ideas??
Old Oct 18, 2021 | 08:44 AM
Gordy M's Avatar
Gordy M
If the Harmonic Balancer is cracked and you shredded belts, the check your instrument panel will light up like a Christmas tree. It can cause the engine temps to rise past 260, check engine light, etc. When you replace the HB use an aftermarket one with an ARP bolt, they are easier to install and safer. The OEM bolt is torque to yield and prone to get loose at high RPM's and the OEM HB is know to separate. Mine let go at a track and also wiped out a streak on the hood padding.
if you drive far
