O2 sensor issue
Old Oct 19, 2021 | 08:14 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default O2 sensor issue
The passenger upstream O2 sensor wiring had worked loose from the frame and cooked on a header. I replaced the sensor and also the connector at the end of the harness. I figured that would be it.
For a hundred miles after clearing the code I was right. Then on the way home late last night this triggered.
Is there a fuse related to O2 at all which I can check? It almost seems like when the prior sensor and harness melted to the metal that maybe it shorted something out. I had previously, years ago, used my Tech 2 to be rid of the non-existent AIR system yet researching some of these codes points to possible emissions systems issue.
Where should I be looking next?
Old Oct 19, 2021 | 08:22 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Fuse #6 in the underhood box is the heater for all 4 oxygen sensors. I went through some oxygen sensor issues recently, documented here:
https://www.corvetteforum.com/forums...-no-codes.html
