Sitting on my Ass
Old Oct 20, 2021 | 09:05 PM
VETTRK's Avatar
VETTRK
Default Sitting on my ***
Pulling out the seats for a tear down.
But I disconnected the main harness in prep for pull drivetrain.
So.....
Passenger seat is all the way back. I don't have power going to the seat. Is there a manual way to crank them forward? I can't get access to the rear post nuts.
is my only option to run 12v to the harness and pray the seats works properly and moves I power it.
Any ideas appreciated
Old Oct 20, 2021 | 09:11 PM
Autoeng's Avatar
Autoeng
That is the only way to do it. They cannot manually be moved
Old Oct 21, 2021 | 09:40 AM
Skyking1992's Avatar
Skyking1992
I would recommend you check the Factory Service Manual. I had a seat mechanism go bad on a GM car (not a Corvette) and there was a procedure to move the seat to get at the rear bolts. The procedure was to disconnect one of the drive cables, put it in a cordless drill, and move the seat forward. Not sure if that is possible in the Corvette, but there must be a way.
Old Oct 21, 2021 | 10:03 AM
VETTRK's Avatar
VETTRK
Thanks, I'll try that.
Old Oct 21, 2021 | 10:28 AM
Old School's Avatar
Old School
I've just finished up a project of mounting a seat to the oem power seat track and I don't see how this would work easily on the corvette seat track. You would have to disassemble in place the worm gear on both sides of the track.
I think you can either fold the seat forward and jam your hand behind the seat with a 15mm wrench and loosen the nuts a 1/8 of a turn at a time
or you can try to remove the 4 torx screws (2 on each side) underneath the rails holding the rails to the forward/back lead screws and slide the seat forward.
Old Oct 21, 2021 | 05:27 PM
johnson-rod's Avatar
johnson-rod
Or you can re-attach the battery and remember not to do that again.
Don't ask...
Old Oct 21, 2021 | 05:47 PM
VETTRK's Avatar
VETTRK
Don't ask...
not that simple, battery, wires, fuse block all pulled
But I figured it out
Got a 14v drill battery, fed power and it moved
Old Oct 22, 2021 | 02:30 PM
hron61's Avatar
hron61
To Sitting on my Ass
