How Hard is a DIY Outer Tie Rod End Replacement?
Old Oct 23, 2021 | 04:18 AM
olikatz's Avatar
olikatz
Default How Hard is a DIY Outer Tie Rod End Replacement?
Looking to change the outer tie rod ends for the front and back. I've seen some videos on YT about how it's done. Does it simply entail loosening the nut on the tie rod and then twisting off the tie rod end and doing the reverse to put on a new end? 'm planning on just putting OEM ones on. Basically I was wondering if there is anything that I am missing or would need to look out for in order to do the job?
Old Oct 23, 2021 | 06:14 AM
VetteMed's Avatar
VetteMed
Yes, it's pretty straightforward, but sometimes the tapered shaft fitting where the "ball joint" end of the tie rod mates with the knuckle can be a little stuck, requiring a puller tool or careful use of a hammer or pickle fork. You will need an alignment after replacement, but you can get close by measuring and marking the position on the threads of the adjustment rod. Note that some tie rod ends may have different overall length than whatever is being replaced, so the overall length of the part needs to be taken into account as well.
Old Oct 23, 2021 | 09:09 AM
MrMcE's Avatar
MrMcE
Hardest part for me is removal depending on how stuck it is. I've had to torch a tie rod on another car I replaced tie rod on
Old Oct 23, 2021 | 05:42 PM
1wholikescars's Avatar
1wholikescars
The hardest part of the job is getting the tie rod off of the bushing. Make sure you can get an Allen key into it to hold it still while taking off the nut. Once you have that, you are 90% through any challenge left.
Old Oct 24, 2021 | 09:47 AM
No-autotrans.'s Avatar
No-autotrans.
It probably depends on where your car is from, mine practically fell out once the nut was removed.
Measure stud to stud on the fronts, stud to somewhere repeatable on the rears, (write that number down!) then loosen the lock nut, it's much easier than after it's hanging there.
Take the nut off the stud, it's a lock nut so you will need the Allen wrench as posted, assuming they're OEM.
If it does not fall out, tap the end of the stud a few times. If that doesn't work tap sideways on the knuckle that it sits in. DON'T whack either one too hard, you can bend that aluminum.
If it still doesn't come out you will need a separator tool.
Then unscrew them, screw the new ones on approximately the same amount, right up to the lock nut, it doesn't hurt to use never seize.
Stick the stud in the hole, pull it in as far as possible, measure to see if you're close to that previous measurement that I hope you you wrote down, adjust as needed, tighten the nut, AND MEASURE/ADJUST AGAIN.
Now you can safely drive it down to the alignment shop to get it properly aligned.
Old Oct 24, 2021 | 10:35 AM
grinder11's Avatar
grinder11
The way it works best for me is to clean the allen head screw with compressed air first. Then get the correct size Allen wrench to insert into the tie rod screw/stud. This will allow you to remove the nut, otherwise the nut will just spin the screw without actually loosening it. With the correct size wrench or socket, loosen the nut until it's flush, or barely above, the male threads. Get a large hammer, and hit the nut a couple of hard raps. If it won't break loose off of the tapered fit, use a propane, or acetylene Torch to heat the outside of the area the tie rod stud goes up through. Then try a couple more hard, sharp raps. It should pop loose. I always use an acetylene torch for heat, before beating on the nut and stud.....Hope this helps....
Old Oct 25, 2021 | 02:13 PM
RonSSNova's Avatar
RonSSNova
Getting the ball joint out of the A-arm should be easy.
If the threaded portion where it screws onto the rack shaft is rusted together, you are gonna be pissed. Croil, or WD40’s new penetrating lube and heat will be your friends.
To How Hard is a DIY Outer Tie Rod End Replacement?
