AC Issue
Old Oct 23, 2021 | 04:16 PM
chblyth's Avatar
chblyth
Default AC Issue
Just had my serpentine and AC belts replaced, no noises coming from the belts but my AC is not nearly as ice-cold as it was just before the replacement. Any ideas as to what might have been re-installed improperly? Thanks!
Old Oct 23, 2021 | 05:00 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
May be just low on refrigerant but hard to say without testing.
Old Oct 23, 2021 | 05:04 PM
chblyth's Avatar
chblyth
Fine to top-up or always drain/replace?
Old Oct 23, 2021 | 05:33 PM
C5 Diag's Avatar
C5 Diag
First make sure you have NO leaks then recover and refill !!
Old Oct 23, 2021 | 05:44 PM
chblyth's Avatar
chblyth
Would there be a sudden leak after replacing the belts? Would anything have been touched to create this issue? Just trying to figure out why it started the day I got my car back from the shop!
Old Oct 23, 2021 | 05:47 PM
C5 Diag's Avatar
C5 Diag
Really hard to say but best to see if you’re low on refrigerant first !!
Old Oct 26, 2021 | 10:37 AM
grinder11's Avatar
grinder11
Now that the newest C5s are nearing 20 years old, many coincidental things can, and do happen. If it were me, I'd probably do what C5diag says. At a minimum, I'd probably put the A/C setting on the coldest temp, turn the fan on high, pop the hood, and see if the compressor is engaged. If so, see if the low side line is cold/whitish color with frost. Best of luck to you.....
To AC Issue
