Loose oil pan bolts
Old Oct 23, 2021 | 05:30 PM
six-drums's Avatar
six-drums
Default Loose oil pan bolts
Went for oil change before she goes into storage and the mechanic who replaced the lower pan gasket last summer remembered my car and decided to retorque the bolts and found most of them loose. He told me to bring the car back next spring and he will check the bolts again. Could this have happened by vibration? Thanks to all. BTW this guy is a real good mechanic and many swear by him.
Old Oct 24, 2021 | 08:51 AM
Moved to C5 Tech, but the bolts should not come loose by vibration. I never had that problem with any of the three C5s I had.
Old Oct 24, 2021 | 10:45 AM
grinder11's Avatar
grinder11
I agree. If the OPs pan bolts came loose after he tightened/torqued them down the first time, he didn't do something right. It's also puzzling to me why he'd need to inspect them a 3rd time!! Perhaps this "mechanic" isn't all what the OP heard about him. As long as he's not charging the OP to inspect them, I guess it can't hurt anything. But if they're loose next spring, and he torques them a third time, 3 times don't make the charm in my book, and I'd be looking for a new mechanic....
Old Oct 24, 2021 | 11:19 AM
six-drums's Avatar
six-drums
Wow, thank you for your reply. If this mechanic did forget to tighten the bolts when doing the gasket l wonder why he would admit that the bolts were loose. He should of tightened them on the down low and not mention it to me. Makes me wonder really. Next spring l will get the bolts looked at and l will look for a new mechanic because this incompetence scares me.Thanks again.
Old Oct 24, 2021 | 12:30 PM
oharal's Avatar
oharal
Those bolts have a very low torque spec and can easily be stripped out. Im guessing the grease monkey used his calibrated torque fingers to tighten them to spec with his "years of experience" and blew the threads out. Every time he sees the car its weeping because the bolt holes are reamed out so he "tightens" them some more which of course is completely ineffective. Just my theory since other possibilities are pretty unlikely.
Old Oct 24, 2021 | 03:27 PM
grinder11's Avatar
grinder11
Yup, tighten em up til they strip, and back em off a quarter turn!!!
Old Oct 24, 2021 | 05:50 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
THAT'S my line!!!
FWIW, 2-3 years ago, I began to notice that my oil pan was "wet". No drips, at that point, but covered in a film of oil. I checked the shop manual for the torque spec, then broke out the torque wrench. I found that ALL of the lower oil pan bolts weren't tight to spec.....
Old Oct 25, 2021 | 01:15 PM
helga203's Avatar
helga203
Originally Posted by leadfoot4
THAT'S my line!!!
What size was the TR 4" long.
To Loose oil pan bolts
