Strange TPMS issue
Old Oct 25, 2021 | 06:54 PM
inkfreq's Avatar
inkfreq
Default Strange TPMS issue
Two weeks ago I had four tires put on my 99. Afterwords the two rear TPMS stopped reading. Brought it back and they said they were bad sensors.
So I ordered two new ones. Brought I back and now the two rear won't activate and one front won't activate.
Any ideas?
Old Oct 25, 2021 | 11:59 PM
gimp's Avatar
gimp
Tell us how you initialized the system?
Old Oct 26, 2021 | 12:01 AM
inkfreq's Avatar
inkfreq
Tire shop did it. They used an electronic tool, and then a magnet when that didn't work.
Old Oct 26, 2021 | 04:00 PM
gimp's Avatar
gimp
I might consider bringing the car to a more knowledgeable shop, that knows how to do the weird corvette things. It should work without any weirdness.
Old Oct 28, 2021 | 12:07 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
The C5 use a magnet, and the C6 uses a relearn tool.
I think if they don't know how, if they started using relearn tool.
Old Nov 2, 2021 | 02:40 PM
MAC5's Avatar
MAC5
You didn't mention if either you or the tire store went thru the "Tire sensor training" process accessed via the DIC, here's a link to a quick video to relearn all the sensors
Old Nov 10, 2021 | 10:12 PM
inkfreq's Avatar
inkfreq
Just an update in case anyone ever wanders across the same issue.
One of the sensors was bad out of the box. It's the one installed in the rear passenger side, so it's the third in line for learning.
Since that was bad, neither it nor the read drivers would learn.
Got it swapped, problem fixed.
To Strange TPMS issue
