Tips on tracking down pulley/belt squeak please?
Old Oct 26, 2021 | 04:35 PM
waddisme's Avatar
waddisme
Default Tips on tracking down pulley/belt squeak please?
Any way to tell which pulley is squeaking? Run motor briefly without belt and no squeak. Would that eliminate crank pulley? Switched out tensioner and have new AC compressor. Car is tracked so it does run some at 7K rpms, but is also daily driven. Suggestions?
Old Oct 26, 2021 | 06:54 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Hope this helps !!…can also be a misalignment issue !!
Old Oct 27, 2021 | 11:43 AM
waddisme's Avatar
waddisme
Great vid. Will follow those steps tonite.
Old Oct 27, 2021 | 11:58 AM
G_Loc's Avatar
G_Loc
How long did you run the engine for without the belts? Was it a constant squeak or did it vary with engine speed? Could also be the exhaust hanger springs. Greasing them up takes care of the issue.
Old Oct 28, 2021 | 01:14 PM
newmember2121's Avatar
newmember2121
Navigator
theres a ton of pulleys on these cars (two idler, two tensioner, p/s, harmonic, ac, alternator, water pump, etc.) I would disconnect the ac belt and narrow it down from there. chances are its your harmonic balancer though if that has never been replaced.
Old Oct 28, 2021 | 04:08 PM
Autoeng's Avatar
Autoeng
If you have an oil catch can that can cause what it perceived to be a belt squeak. See mycorvettelife on youtube for his journey trying to find a squeak that wasn't a squeak...
Old Oct 28, 2021 | 05:03 PM
grinder11's Avatar
grinder11
If you've spilled any antifreeze on the belts, they will eventually squeal. I have over 120,000 miles on my pulleys/tensioner, all original, except the ASP balancer. Mine squealed terrible after spilling Dex Cool on them changing the t-stat. Squealing was so bad, I was ashamed to drive it. I thought about buying new pulleys, or a new tensioner. But when I removed an idler wheel, I measured the very slight wear in the middle caused by the belt running over it a million times, and wear was only .015"!! The bearing(s) felt fine, and smooth. So I bought only new belts, and the squeal disappeared. Just sayin'......
To Tips on tracking down pulley/belt squeak please?
