2004 C5 Suspension recommendations
I have 04 Coupe (factory wheels). I am looking to upgrade/improve the shocks and sway bars (no polyurethane bushings). I am looking at C6 Z51 equivalent sway bars and either c6 Z06 shocks or Bilstein shocks. I don't autocross, but drive pretty aggressively around town when I can. Just want to tighten everything up.
Sway Bars - Hotchkis Sport 2285 front (31mm) and rear (25mm) Can't go bigger on stock wheels and tires, due to oversteer
Shocks - C6 Z06 or Bilstein for the Z51
I am not lowering the car and don't want to spend a fortune on the new setup. $1000-$1500. Any suggestions?
metal end links $400.00 pretty tuff to beat bang for the buck imo. They have packages with C6 Z06 shocks as well as Bilsteins separately.
I have these bars with the non -lowered Bilstein B6s if I rermember correctly as replacements on my 07 C6 that had the base suspension
and it is a great combo on the street with out being to harsh.
I assembled the following for my car and it handles extremely well for a Vert:
C6 Z51 front spring
C5 Z51 rear spring
C5 Z06 front sway bar
C6 Z51 rear sway bar
Poly bushings
Metal end links (if not already equipped)
I sourced the springs, and sways used. The end links were new.
C6 Z51 sway bars and end links
GM/ACDelco sway bar bushings
C6 Z06 shocks
Elite Engineering's "Abs -of Steel" thermal tunnel plate
