Sway bars
Old Nov 2, 2021 | 09:16 AM
2003_Coupe's Avatar
2003_Coupe
Default Sway bars
I bought a used set of Zo6 bars for my 03 base. The bushings are a bit dry rotted. I'm only seeing poly bushings aftermarket. Are there any companies making rubber ones that are any good? Also the sway bars are a little rusty underneath where the bushings clamp to, should I just run them or get them re-powdercoated?
Old Nov 2, 2021 | 10:42 AM
BmoreRnsDeep's Avatar
BmoreRnsDeep
I think if you put it in a search on amazon it will give results for the donor car. For example put in a 2003 ZO6 as your car and search for sway bar bushings. Most will come up with MM results so know the measurements of the bars.
