Is there any point installing a CAGS - skip?
As you know, the original programming takes advantage of the engine torque to force a shift into fourth gear rather than running through the gears normally from low speed.. It is speed and throttle related in a very specific way, so you might look up the operating perimeters before making a buying decision . I haven't memorized them or I would offer them here. I am generally running more throttle around town from take off than what activates the CAGS system, and I am just keeping up with traffic, most of the time.
I just wind out the engine until it sounds like time to shift, being aware of the design limits , and the program has only interfered twice since owning the car, both times when in a slow left hand turn from stop, where acceleration was reduced by traffic, and running low partial throttle. I have since learned to anticipate the activating conditions and try to think ahead to avoid it.
I don't like the feel of running fourth gear at low speeds, as I am used to much lower torque engines, so it feels to me as though I am lugging the engine, which I know, according to GM, it is not. I just like to rev and shift by ear, having learned the engine power and shift points , my only concern is over revving , which I don't do but by mistake. I get around town using 15 mpg per calculations from pump measurements. Gm says I should get 18, with a lot of people posting they get those figures.
I see a lot of posts where this part is recommended no matter what, and I don't agree. To me it is only adding a potential additional failure point, un-needed for my enjoyment. Some people enjoy adding on any possible item , while others , more like myself, follow recommendations posted because I don't know better, and figure others do. Others might do a lot of low speed part throttle driving below 25 mph and make fine use of a very favorably reviewed product.
Had it tuned out also when I was having it tuned for headers and intake.
