Torque Tube Rubber Coupling Need Replacing?
I just got a 2004 C5 Corvette with an automatic transmission, and it has 24K miles on it. It is a one owner and it is in really good shape. It also appears that the car was well maintained and it was not hammered on. I have been looking into some simple mods so I contacted a local Corvette shop. In a conversation with a very experienced and reputable Corvette mechanic the topic of the torque tube and the rubber couplers (guibos)? came up. I was told that it is a good idea to change them out because if they are not already bad, it is just a matter of time before they will be.
He said that even if the car was not driven hard to create a problem, that time can be an issue for them too as they crack and become brittle. He stated that it is a known weak link with C5 Corvettes. For mods I will not be increasing the stock HP, as I am only interested in doing some suspension mods, and some new wheels and tires. I for-sure am doing new cat backs and an cold air intake.
At this time it seems like I have no apparent problem that I know of concerning the rubber couplers. I like being proactive, but when I learned of the cost and labor to do this work I almost passed out. I guess if you are going to the trouble of replacing them you should just rebuild the entire torque tube. Should I be proactive and have something repaired that isn't broke yet? Is this just an accident waiting to happen and I will be doing these repairs down the road?
If the rubber couplers fail what sort of damage will happen to my Vette? I will be retiring next year and I have more disposable income now. Please advise, and thank you in advance.
Thanks, Edgemere
The guy at the shop who pressed in the new TT bearings said these guibos were in pretty bad shape
Thanks, Edgemere
If you plan on addressing this, I would recommend the following for your consideration:
In addition to the torque tube, replace the trans seals. Not a rebuild, just the seals. The rear crank shaft seal is another item to check.
Change rear end gears. Probably the best bang for the buck, and 3.42s will wake up performance without adversely affecting daily use.
A higher stall converter. Not a race high stall, but something around 2000 rpm so “when” you decide to add a street cam, you won’t have to worry about creep while idling. You won’t even notice that level of stall daily driving, but it will give more power off the line.
I know you stated you only wanted suspension mods, but that’s what I said before…😁
