Clutch Noise?
Old Nov 6, 2021 | 01:38 AM
DarkPoet94's Avatar
DarkPoet94
Default Clutch Noise?
Hi all,
I picked up a 2002 6 speed this summer. It is bone stock as far as I know. It runs great, and it drives wonderfully. I was backing into the garage tonight and had the radio off. I noticed that I heard what sounded like a squeaky hamster wheel. I took put it in neutral and took my foot off the clutch to sit still. The sound went away. I pressed the clutch to the floor, and the hamster wheel squeal / squeaking started up again. Foot off - gone. Foot to the floor - squeak. It wasn't terribly loud, and it didn't sound like grinding. My first thought was a worn throwout bearing. The car is flirting with 80k miles. I hope the previous owner didn't sit at red lights waiting in gear. Is this something common with the car, or is this something I am going to need to need to work on short term? Thanks in advance for responses.
Old Nov 6, 2021 | 05:25 AM
bobick's Avatar
bobick
Here is how my old release bearing looked like at 53k miles. Had no strange sounds while driving though.
If yours is noisy, then I think it is almost dead.
Old Nov 6, 2021 | 11:29 AM
helga203's Avatar
helga203
From my understanding has nothing to do with drivetrain. when u press clutch down it releases all drivetrain notnining movers so that will rule out all component clutch back. Correct me if im wrong.
Old Nov 6, 2021 | 12:58 PM
Justin Raney's Avatar
Justin Raney
Depends two times i had the stock clutch and a spec 2+ throw a spring that wedge in between pressure plate and clutch but maybe not your problem. Not sure only problem it caused was the clutch wouldnt disengage probably a different issue here though. Helgas probably right if clutch disengages or still functions. Think it rode in the center flywheel section but maybe wrong.
Old Nov 6, 2021 | 01:16 PM
DarkPoet94's Avatar
DarkPoet94
https://youtu.be/yHNrLB0X-5o
That doesn't sound like my sound. Mine is a high pitched squeak, not a low tone grind.
Old Nov 6, 2021 | 01:18 PM
DarkPoet94's Avatar
DarkPoet94
Everything works properly. Clutch works as intended.
Old Nov 6, 2021 | 01:33 PM
bobick's Avatar
bobick
Now imagine this low tone grind at 700 rpm My bet - the bearing is shot.
With clutch pedal at the floor the only loaded rotating parts are the release bearing and pressure plate. Clutch disk and torque tube are not moving. I don't see any way pressure plate can produce such sounds, so...
And yeah, it may last for some time, but you never know when it'll break.
Old Nov 6, 2021 | 02:37 PM
DarkPoet94's Avatar
DarkPoet94
Yea that was my gut feeling. Guess I’ll keep an ear on it for now.
To Clutch Noise?
