owner whose installed Bilston shock
Old Dec 23, 2002 | 08:24 PM
00c5coupe's Avatar
00c5coupe
Default owner whose installed Bilston shock
does is come with just a rubber bushing and big washer? and you suppose to use stock bolts to install it? That is all i have, see pix below....I bought it used. Can i installed it with just what i have? Should the big washer sit under the bushing then the boot and finally the c-clips (all of this is the bottom part)? thanks
[Modified by 00c5coupe, 9:11 PM 12/23/2002]
[Modified by 00c5coupe, 9:41 PM 12/23/2002]
Old Dec 23, 2002 | 09:03 PM
MySea6's Avatar
MySea6
Default Re: owner whose installed Bilston shock (00c5coupe)
Yes on the stock hardware but you should have more than one bushing/washer per shock.
Ooops, not totally accurate. Each shock comes with a nylock nut also but your right, use stock bolts.
[Modified by MySea5, 8:05 PM 12/23/2002]
Old Dec 23, 2002 | 09:12 PM
MySea6's Avatar
MySea6
Looks like you have everything below the boot. Is there a c-clip on the shaft that keeps the washer from falling off? The boot also clips down over it,
I guess that you could use the stock upper mount bushings & washers although Bilstein supplies new ones. I would get some nylock nuts though.
Old Dec 23, 2002 | 09:19 PM
00c5coupe's Avatar
00c5coupe
Default Re: owner whose installed Bilston shock (MySea5)
yes, there is a c-clip on each of them. So everything should be the bottom right? You mention the boot (the blue piece in the pix?) should be underneet the c-clips? Thanks for your help
Old Dec 23, 2002 | 09:42 PM
MySea6's Avatar
MySea6
Yup, looks like you have everything for the bottom of the shock. The boot just slips down over the top of the c-clip. That bushing, in the pic, is your downward suspension bump stop. :thumbs:
Old Dec 23, 2002 | 09:53 PM
jschindler's Avatar
jschindler
:iagree: He's the man on Bilstein installs (helped me install, and uninstall a set)
Old Dec 23, 2002 | 10:01 PM
00c5coupe's Avatar
00c5coupe
thanks MYSea5, I will try to install them tomorrow.
To owner whose installed Bilston shock
