Low oil level
Old Nov 13, 2021 | 10:00 AM
dskinsler83's Avatar
dskinsler83
Default Low oil level
So I constantly get a Low Oil Level coming up on my dash. I am thinking it is a ground issue. Anyone had this issue? I have checked the oil and the level is fine and the car has oil pressure.
Old Nov 13, 2021 | 10:03 AM
grinder11's Avatar
grinder11
That's a new one on me! You're probably right, either bad ground or sensor.....
Old Nov 13, 2021 | 10:23 AM
helga203's Avatar
helga203
Had the same problem. Wire was rubbing on the oil pan.Don't know if ur is the same but start there and check the connections to sensor.
To Low oil level
