Sticky Steering Wheel
Old Nov 18, 2021 | 07:12 PM
Jerstoy's Avatar
Jerstoy
Default Sticky Steering Wheel
The center where the air bag is located it is REAL sticky, any idea on to clean this, is much appreciated.
Thank you all,
Jerry
Old Nov 18, 2021 | 07:52 PM
Mickeyrx70's Avatar
Mickeyrx70
Pretty common problem. Some use Goof Off to remove the sticky material. I had success by dampening a cloth with Simple Green then draping it over the airbag cover for about 30 minutes or so. Then I used the cloth to rub off the stickiness. The airbag cover was somewhat dull afterwards, but regained its luster after I applied some Aerospace Protectant 303. That was years ago and it’s been fine since. Check C & S Corvette on YouTube - - they use Lemon Ammonia. If your airbag is shale colored, you’ll probably have to repaint it after you get the stickiness off - - - no problem if it’s black.
Old Nov 21, 2021 | 09:35 AM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
What is that sticky substance that oozes out?
dan k.
Old Nov 21, 2021 | 06:49 PM
MikeTN77's Avatar
MikeTN77
I had this problem and tried all sorts of stuff, including goof off. What ended up working was straight rubbing alcohol and a lot of elbow grease and scrubbing. Took about 45 minutes, but it is as good as new now.
It is my understanding that the stickiness is a breakdown of the factory plastic, for whatever reason. C&S corvettes has a great video on this, and another suggestion on a fix.
Old Nov 26, 2021 | 06:44 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Thank you all,
Jerry
I also used lemon ammonia and it did not take long to completely fix the problem...it was amazing...then i used the 303 and i am thrilled about how it looks and feels...I suffered for a long time with the sticky ****...i kept puttuing off trying to fix the problem...stupid me ...I keep wondering how long the fix will last......but i am enjoying the hell out of the feel and look so far...
Old Nov 26, 2021 | 09:28 PM
Jerstoy's Avatar
Jerstoy
Thank you, Jerry
Old Nov 27, 2021 | 03:24 AM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
Probably not the best solution, but it worked for me. I wiped mine down with a rag and lacquer thinner. It removed all the stickiness. I then wiped it down with 303 interior restorer which restored the shine without the tackiness.
Old Nov 27, 2021 | 10:16 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
you will ruin many interior surfaces if you happen to get lacquer thinner on them...just sayin
Old Nov 27, 2021 | 02:19 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Water-based Goof off and sacrifice a few MF towels to remove the residue. The air bag material is more porous than the other interior vinyl so the stick residue is usually a result of years of topical coatings coming out of the surface. Mine was fine until a dealership service department parked my car out in the hot summer Florida sun for two days. That was five years ago and after cleaning off the residue I've applied light coatings of Aerospace 303 protectant with no problems since.
Old Nov 27, 2021 | 11:12 PM
vette4fl's Avatar
vette4fl
Default Oxyclean
Not only will oxyclean remove the sticky, it actually solves the problem!
Something about the ingredients are the same thing used to solidify the plastic in the first place. I recall that it had to do with oxygenating the plastic.
Mix some oxyclean with a bit of water to make a paste. Use a soft toothbrush to work it into the plastic and get into the crevices. Then use a damp towel to work the surface as needed, then wipe it up. Takes a little elbow grease and a couple of applications, but it works and won’t harm anything in your interior. My wheel and some areas around switches came out like new, and no regression nine months later.
Old Dec 29, 2021 | 08:20 AM
slothman's Avatar
slothman
303 is an excellent product. for removing any "****" I like to use magic erasers. Always do a test spot of course.
Old Dec 29, 2021 | 11:47 AM
TommyC5/4's Avatar
TommyC5/4
Thank you all,
Jerry
I ordered a new airbag cover from Apsis..a little pricey but to me it's worth it ..far better that the OEM cover...
Old Oct 13, 2022 | 10:59 PM
Yvette1's Avatar
Yvette1
2nd Gear
Here is the link to another forum I am associated with and my post>
https://www.digitalcorvettes.com/thr...kiness.296207/
Old Oct 14, 2022 | 12:46 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
I have had this experience only on the Z06. I suspect it may be a combination of the type of plastic used and some cleaner which someone along the way had used on these cars to cause the gummy outcome. I say this because I hate slippery and greasy teflon injected cleaners which most people use on interiors. I only use water and damp wipe it down and on my 2000 and my 1999 Coupes I have never had this issue. But the problem also exists on my S600 and came with it - and it only affects one area in the car despite the same plastic material being present throughout. Just near the wheel.
That's my conspiracy theory anyway.
But the ammonia and the oxy both sound like good options to try when the time comes.
Old Oct 14, 2022 | 10:05 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Jan 4, 2023 | 10:25 PM
Always wanted1's Avatar
Always wanted1
4th Gear
Default Sticky steering wheel
Thank you all, Jerry I just bought my 1 st vette c5 triple black & wiped air bag cover with a cotton rag with ordinary windex mixed with ammonia from ace hardware . It removed all residue but not vynal color . Still sticky free 4 months later!
Jerry
try it but not too much ammonia
Old Jan 6, 2024 | 07:44 PM
davcono's Avatar
davcono
After stripping use liquid heel and sole shoe polish to restore to original sheen.
Old Jan 8, 2024 | 01:21 PM
Tron Z's Avatar
Tron Z
I finally addressed this problem on my car a couple of weeks ago. I used powdered Oxiclean and it works great.
To Sticky Steering Wheel
