Screeaching from behind dash
Old Nov 23, 2021 | 01:52 AM
thevelvetglove's Avatar
thevelvetglove
Default Screeaching from behind dash
Ok I was told I had to remove the dash to get at the broken speaker. My question is can I not simply pull a fuse or cut a wire to disable it. Thx
Old Nov 23, 2021 | 01:19 PM
VetteMed's Avatar
VetteMed
Are you referring to the chime for the instrument panel? There's no speaker for the stereo system in the dash in a C5.
Old Nov 27, 2021 | 11:11 AM
BACNBLK's Avatar
BACNBLK
I had the same issue with my 01, sounded like a fax modem squeal. You will need to remove the cluster and then remove the speaker.
a few good articles on this forum to help you out, hardest part was getting cluster around the steering column, the rest was easy
good luck
Old Nov 27, 2021 | 12:54 PM
thevelvetglove
Ok I guess the cluster comes out this weekend
Old Nov 29, 2021 | 11:10 PM
vette4fl's Avatar
vette4fl
While you’re in there… This would be the right time to add some led lights!
BTW, there are YouTube videos on removing the cluster.
Old Dec 4, 2021 | 03:27 PM
thevelvetglove
Ok thanks going to do it this weekend
To Screeaching from behind dash
