Abs and Srs Diagnostic Codes
Old Nov 26, 2021 | 10:57 AM
zumbahlenm's Avatar
zumbahlenm
Default Abs and Srs Diagnostic Codes
Hello can someone help me with these codes I pulled. I am not familiar with them.
Chevrolet ABS
C1278 - TCS Temporarily Inhibited by PCM
U1000 - Class 2 Data Link Malfunction
Chevrolet SRS
B0091 - Active Switch: Wrong State
U1016 - Lost Communication with Powertrain Control Module
U1040 - Lost Communication with Electronic Control Module
U1096 - Lost Communication with Instrument Cluster
U1064 - Lost Communication with Body Control Module
Old Nov 26, 2021 | 02:31 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The 4 modules...PCM, EBCM, IPC, and BCM are powered either through the battery or ignition switch...these U codes are "communication" DTC's so some modules can't "talk" to others...all 4 of those modules are powered by 1 of 4 wires through that ignition switch so you MAY have a bad ignition switch but without testing I can't guarantee that...how old is your battery ??...that should be the first thing tested...don't worry about the B0091 or C1278 for now.
Old Nov 27, 2021 | 10:02 AM
zumbahlenm's Avatar
zumbahlenm
I just replaced the battery.
The ignition switch was changed by the previous owner. He had told me plus given me about 3 extra set of keys.
Old Nov 27, 2021 | 11:51 AM
C5 Diag's Avatar
C5 Diag
I wouldn’t go by “he told me he changed it”…you can erase the codes and see if they come back…I’d ensure the battery is at least 12.66 volts to make sure it is fully charged.
To Abs and Srs Diagnostic Codes
