Blackwing or VorteX Rammer
Old Dec 25, 2002 | 03:10 AM
vrumvrum's Avatar
vrumvrum
Default Blackwing or VorteX Rammer?
OK time to start digging into the engine compartment. :yesnod: Should I go with Vortex Rammer or Donaldson Blackwing? What if I add a ported throttle body? How much can a stock manifold flow?
[img]www.seanet.com/~mstanzel/vettepic//frontvw.jpg[/img]
[Modified by vrumvrum, 8:13 AM 12/25/2002]
Old Dec 25, 2002 | 05:54 AM
Austrian Vette's Avatar
Austrian Vette
Default Re: Blackwing or VorteX Rammer? (vrumvrum)
I like the Vortex a lot.
Michael
Old Dec 25, 2002 | 08:20 AM
Mitch C's Avatar
Mitch C
I have the Black Wing and I like it. The Vortex is also very good but if you drive your car in the rain you stand a greater risk of hydro locking your engine. Because you have to cut your shroud to use it's cooler air feature. I doubt if you will see much of a gain in RWHP with a ported throttle body especially with a stock engine. I can't tell you how much the manifolds flow.
98 A4
Donaldson Blackwing
Cartek Stage 2 Heads
Cartek M Cam
LS6 Intake
TPIS Headers
Underdrive Pulley
Comp Push Rods
ST3500
3.73 Gears
B&M Trans Cooler
172 t.stat
[Modified by Mitch C, 7:21 AM 12/25/2002]
Old Dec 25, 2002 | 11:12 AM
art91's Avatar
art91
Default Re: Blackwing or VorteX Rammer? (Mitch C)
I have a Vortex. Just installed it 2 days ago. It works well, but the Blackwing is an easier install, and does not involve cutting the shroud. If you plan to drag race, the Vortex would probably help on the top end. If it's just a pleasure driver, the Blackwing will do fine.
:cheers:
Old Dec 25, 2002 | 01:43 PM
Don&Kelly's Avatar
Don&Kelly
I had the Vortex & liked it alot - I switched to te VaraRam & like it too - you might want to look at the VaraRam too .. Cold air rules ...
:cool: :cheers: :smash: :seeya
Old Dec 25, 2002 | 02:51 PM
DsC5's Avatar
DsC5
:iagree:
Old Dec 25, 2002 | 03:03 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
I have tried all three and in my opinion the Vortex is the best of them. I jsut seem to feel it a little more. Could be wrong just my opinion.
Old Dec 25, 2002 | 04:33 PM
MagRedSkull's Avatar
MagRedSkull
You're in a state with alot of rain so bottom breathers (Vortex) can be risky when encountering puddles. You may not always be able to avoid the puddles, I thought I could avoid them in CA. I have/had the Vortex, but since I hydrolocked my engined on 12/16/02 , I will be switching to a Blackwing when the motor gets repaired. I liked the Vortex performance, but I gambled & lost. Your choice.
Old Dec 25, 2002 | 05:02 PM
vrumvrum's Avatar
vrumvrum
:eek: :eek: ENGINE REPAIRED BECAUSE YOU DROVE THROUGH A PUDDLE !!!!???? That's not a risk I think I want to take. :nonod:
Old Dec 25, 2002 | 05:13 PM
OhNiner's Avatar
OhNiner
I like my Blackwing, easy to install, easy to return to stock.
Old Dec 28, 2002 | 02:55 AM
TIKTGTR's Avatar
TIKTGTR
Default Re: Blackwing or VorteX Rammer? (Gardiner)
Have you thought about the K&N FIPK system? I love mine and it also has the bigger air bridge; not to mention the K&N warranty!! Just my .02 :seeya
Old Dec 28, 2002 | 10:14 PM
BIG Dave's Avatar
BIG Dave
Default Re: Blackwing or VorteX Rammer? (TIKTGTR)
I went with the Blackwing. Easy to install, easy to un-install. Just don't forget to get the hood seal.
Old Dec 28, 2002 | 10:34 PM
99inDenver's Avatar
99inDenver
I went with the Blackwing and am very happy with it.
Old Dec 28, 2002 | 11:24 PM
evil-1's Avatar
evil-1
Default Re: Blackwing or VorteX Rammer? (99inDenver)
././././....Both are great, I've seen Ease scans that hardly differ between the two with air intake volume........... :yesnod:
To Blackwing or VorteX Rammer
