Slave cylinder disconnect
Old Dec 6, 2021 | 12:02 PM
Ginger’s C5's Avatar
Ginger’s C5
Cruising
Default Slave cylinder disconnect
Hi,
Any recommendations for disconnecting the slave cylinder line? Pushing in the white sleeve is not working.
Old Dec 6, 2021 | 12:42 PM
johnson-rod's Avatar
johnson-rod
Squirt it with silly cone or WD-40 or PB Blaster. It's stuck.
It's also a 3 handed job with no room for the third hand.
I came up with a U shaped tool that pressed both sides of the QD fitting at the same time with no hands and then it just popped off.
Don't give up.
Old Dec 6, 2021 | 02:33 PM
feeder82's Avatar
feeder82
If you can get to the bleeder crack it open and let some fluid out, that helps.
Old Dec 6, 2021 | 04:39 PM
Ginger’s C5
Cruising
This was going to be my next try, but the previous comment did the trick. WD40 and some cuss words!!
Old Dec 6, 2021 | 04:40 PM
Ginger’s C5
Cruising
Don't give up.
This did the trick!! Thank you
Old Dec 8, 2021 | 08:15 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Glad you got it.
I had found a fuel connector release kit. Jammed the right one in this. Then slapped it a few times from behind with a wrench which fit around the line. Came off instantly.
Old Dec 8, 2021 | 01:46 PM
johnson-rod
I used the door handle removal tool for a 1958 Chrysler. I got some weird tools.
To Slave cylinder disconnect
