1999 C5 Lumbar Pump
Old Dec 9, 2021 | 06:37 PM
EMVittore's Avatar
EMVittore
3rd Gear
Default 1999 C5 Lumbar Pump
I removed and repaired my driver side lumbar air pump, but in the process accidentally broke the wire in the picture. Can anyone tell me what this is and does ? Where can I get another one ? And will the motor work without it or will it burn up the motor ? No luck at the auto parts stores.
Old Dec 9, 2021 | 06:51 PM
SilverC54me's Avatar
SilverC54me
that is a capacitor, you would need to take it to an electronics parts house to get a replacement.
The motor will run without it.
Gary
Old Dec 9, 2021 | 07:00 PM
EMVittore's Avatar
EMVittore
3rd Gear
Thanks Gary. I'll try that. Wish Radio Shack was still around.
Old Dec 9, 2021 | 10:08 PM
The Former's Avatar
The Former
Banned Scam/Spammer
I have an extra. You want it? PM me.
Old Dec 10, 2021 | 08:12 AM
grinder11's Avatar
grinder11
Nice offer!! OP-Can you possibly solder the wire to the capacitor?
Old Dec 10, 2021 | 09:19 AM
Davcruz's Avatar
Davcruz
As stated it's a capacitor, looks like the size is written on it but cannot quite make it out, maybe 15 micro farad. You can run without it, it is there to reduce interference to close by RF devices like your radio.
Old Dec 10, 2021 | 06:02 PM
grinder11's Avatar
grinder11
Are you saying you can't solder on the capacitor?
Old Dec 11, 2021 | 11:11 AM
Davcruz's Avatar
Davcruz
Not sure where you got that idea, but no I am not saying that at all. I am saying, you can post a better closeup of the broken capacitor and maybe we can determine the size so you can order a replacement on Amazon OR you can cut the broken one off and use the pump without a capacitor.
Old Dec 11, 2021 | 01:24 PM
EMVittore's Avatar
EMVittore
3rd Gear
The number on the capacitor is 154.
Old Dec 11, 2021 | 03:45 PM
grinder11's Avatar
grinder11
I guess I just like to try and fix things, when possible. In this case, I don't know if it's possible, or not, hence my question whether you were saying it can, or can't, be done. You'd probably have to use a very small (measured in watts) soldering iron, or the excess heat could probably damage the capacitor. I guess if it's cheap and easily sourced, a new one would be best.......
Old Dec 12, 2021 | 08:53 AM
Davcruz's Avatar
Davcruz
I think I get what you where saying now, you are thinking of trying to resolder the broken lead to the capacitor. If there is a bit of lead left on the capacitor, yes you could do that. That is a tantalum cap, so if there is no lead left (usually they break right at the cap) then it is trash and requires replacement. Again, you can run the pump motor without the cap and it will be fine.
Old Dec 12, 2021 | 01:05 PM
grinder11's Avatar
grinder11
If you can do as you're saying, then running it without it is probably what I'd do. I wonder why there's a capacitor there in the first place, maybe to help start the little motor? I've never seen capacitor start systems on anything except larger motors, but I certainly don't proclaim I know everything, and I certainly dont. If it works OK without it, so be it....
Old Dec 12, 2021 | 09:38 PM
Moving this to C5 Tech.
Old Dec 13, 2021 | 08:41 PM
ncali's Avatar
ncali
Why the cap is there
Old Dec 14, 2021 | 05:01 PM
Davcruz's Avatar
Davcruz
OP, sorry for some reason I thought Grinder11 was the OP since he was asking all the questions.
So is 154 the only marking on the cap?
Old Dec 14, 2021 | 05:09 PM
Davcruz's Avatar
Davcruz
Actually, I checked that number, looks like a 150 nano farad ceramic capacitor, which can be looked up as a .15 micro farad as well. There are some assortments on Amazon that will contain that size or very close.
Amazon Amazon
To 1999 C5 Lumbar Pump
