C5 instrument cluster questions
Old Dec 10, 2021 | 02:43 PM
rusty63ss's Avatar
rusty63ss
Default C5 instrument cluster questions
I am using a C5 LS1 in my conversion. I would like to use the C5 instrument cluster in the car.
I am not going to use the BCM. Before I start chopping up the dash I would like to make sure it is going to work.
For the fuel gauge. Can I just ran a wire from the cluster to the sender?
How many ohms does the sender need to be?
Is it possible to turn off the DIC errors for Traction Control, ABS, etc?
Thank you in advance for your help!
Old Dec 10, 2021 | 05:49 PM
wrmiles's Avatar
wrmiles
I looked up the wiring diagram in a Chilton manual available online through my local library.
It shows that the fuel gauge receives its signal from the PCM, with no details on what the signal looks like. So if you are using a C5 PCM, it might work.
Ir might be possible to turn off the other things by reprogramming, but I am not knowledgeable in this area.
Edit to add: It is unclear exactly what your conversion consists of. Keep in mind that the PCM is looking at the senders in two tanks, each apparently varying from 40 to 250 ohms, and it is looking for the right tank to empty first. Otherwise it will drive the gauge to zero and throw a code.
Old Dec 11, 2021 | 12:17 AM
Moved to C5 Tech.
Old Dec 11, 2021 | 03:13 PM
oelarse's Avatar
oelarse
The C5 has two fuel tanks with two fuel senders connected to the PCM as shown below .
Both signals are added in the PCM software to create the fuel gauge fuel level .The fuel level signal is sent from the PCM to the cluster on the serial databus
If one of senders get out of normal range the gauge could drop to zero level .
Each sender operate between 40 and 250 ohm (zero to full fuel level)
Old Dec 11, 2021 | 03:19 PM
ThomasR's Avatar
ThomasR
Unfortunately, no.
Old Dec 12, 2021 | 05:07 AM
rusty63ss's Avatar
rusty63ss
So what I am seeing is if I install two senders in the tank hook one to C2 54 and the other to C2 73 the gauge should work.
Now I just have to figure out how to fool the DIC to think everything is okay.
Old Dec 12, 2021 | 05:10 AM
rusty63ss's Avatar
rusty63ss
Originally Posted by MillennialSnowflake
Unfortunately, no.
Is there some way to fool it into thinking everything is okay? Is it looking for a specific voltage or is it more of a canbus signal that the BCM is sending it?
Old Dec 12, 2021 | 12:31 PM
Old School's Avatar
Old School
from my '03 service manual
Old Dec 14, 2021 | 11:40 AM
grinder11's Avatar
grinder11
Answering this is beyond my knowledge-BUT-If you're going to run the instrument panel, and PCM, why not run the C5 BCM? Seems logical. It takes up little space, and you'd have, I think, a lot better shot at getting what you're looking to do. I'll give you the phone# of someone who'll probably have an answer for you, either way, and they also make wiring harnesses for about anything. VERY knowledgeable, as the owner is Bill Howell, a retired GM electrical engineer. Call Howell Engine Developments@(810) 765-5100, and ask for Troy, or Bill jr.. I'm sure they can help you, or send you to someone who can. Best of luck......
Old Dec 14, 2021 | 02:22 PM
oelarse's Avatar
oelarse
"So what I am seeing is if I install two senders in the tank hook one to C2 54 and the other to C2 73 the gauge should work."
The PCM expect the fuel level (voltage) to drop in the passenger side first until empty level and then the fuellevel (voltage ) in the driverside tank starts to drop untill both fueltank to empty .
If these two fuelsenders voltage levels does not drops correct it will probably set several fuel level sensor performance DTC's
Old Dec 14, 2021 | 03:07 PM
rusty63ss's Avatar
rusty63ss
Lots of great information. Lots more digging to make sure this is going to work. Thank you all for the help!
Old Dec 18, 2021 | 03:17 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Slap a terminator on it and wire up all aftermarket digital gauges.
Old Dec 19, 2021 | 08:33 AM
lionelhutz's Avatar
lionelhutz
There's' probably a way to switch the PCM to using a single sender, or using a different PCM/OS that does. Possibly by segment swapping.
To C5 instrument cluster questions
