Metallic tapping sound from engine on startup
Old Dec 14, 2021 | 03:48 PM
NikolasC5Z's Avatar
NikolasC5Z
8th Gear
Default Metallic tapping sound from engine on startup
When I start my car I head a consistent metal tapping noise. After the car warms up or a short drive the noise is gone. I have attached a short clip of the noise. If anyone has an idea of what is cause this noise and if it is something to be concerned about please let me know.
File Type: mov
Old Dec 14, 2021 | 04:16 PM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
Sounds almost like a belt chirp/squeak. Are you sure it's metal? Try shooting some water on the belts when it's making this noise. If the noise goes away it means it's a belt. Also, valvetrain noises and lifter tick aren't uncommon in these engines. What's your oil pressure at startup when it's making this noise? If it goes away when warm I wouldn't worry about it.
Old Dec 14, 2021 | 11:22 PM
jim993's Avatar
jim993
It sounds like a pulley or tensioner squeak.
Do a search with an automotive stethoscope.
Could also be a water pump bearing, alternator bearing or the like. A/C compressor clutch or?
Old Dec 14, 2021 | 11:55 PM
NikolasC5Z's Avatar
NikolasC5Z
8th Gear
I will take a closer look for exactly where the sound is coming from then. The water pump was replaced a few thousand miles ago so hopefully it is not that. And my oil pressure goes well past 40 psi during a cold start then sits right at 40 at idle.
Old Dec 15, 2021 | 09:30 AM
BRKLYN's Avatar
BRKLYN
The LS 1 does tick sometimes, mine did the other day. Also my 2001 Z/28 also ticked, even more so than my Corvette, they’re know to tick or slap whatever. I found this in LS 1 Tech forum dated 2006, “ I bitched to GM so much about the tick, after the whole run around I finally got all new internals. Guess what, it still ticks. Granted its no where near as bad as before, but it does come back and it sounds like ****. Ive learned to accept it. As long as this thing keeps bitch smackin mustang GTs Im happy.“
I hope this eases you somewhat. Had mine since 06, if it ticks or slaps and runs, drive it and 😀 smile.
Old Dec 15, 2021 | 03:32 PM
grinder11's Avatar
grinder11
Damn, I have to say Ford did a fine job on the Mustang styling. The front ends look great in my passenger side outside mirror!!!
Old Dec 15, 2021 | 05:51 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Pull the belts and start it cold. Go from there.
Old Dec 26, 2021 | 06:02 PM
UM Rebel's Avatar
UM Rebel
My 2004 has been doing that for 18 years. Seems to be from the belts. Goes away after warm up. Maybe I will worry about it after another 18 years and another 150,000 miles. 😎 🍻
Old Dec 26, 2021 | 06:34 PM
Napoleon_Tanerite
I haven't had issues with my Corvette, but my GTO is terrible for belt noise, especially after it sits for a long time (which it tends to do). My dad's 2002 Tahoe pinged something fierce when it was cold, but went away when warm. We confirmed it wasn't belts and stopped worrying about it from there since the oil pressure was always good and the oil always came out clean
Old Dec 26, 2021 | 08:27 PM
johnson-rod's Avatar
johnson-rod
In cold weather mine sounds like a diesel for the first few blocks. I worried about it when I bought it in 2007 with only 20K miles. Somewhere between then and the 150K miles now I stopped worrying about it.
Old Dec 31, 2021 | 08:34 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default Its called piston slap….
Its called piston slap all three of mine did it when cold . it went away once it warmed up a little. I believe there was a Tech Bulletin on it.
To Metallic tapping sound from engine on startup
