EGR Removal?
Old Dec 26, 2002 | 09:06 PM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Default EGR Removal?
I'm using an LS1 in a C1 hotrod project. Will I cause any problem by eliminating the EGR system? I want to weld the holes in the exhaust manifolds and get them ceramic coated. :confused:
Old Dec 26, 2002 | 09:59 PM
1320crazy's Avatar
1320crazy
Default Re: EGR Removal? (vettes1st)
it will not be a problem as long as it doesnt set a code,which can be modified in the tuning,also by using the ls6 intake will give you more power and eliminate the egr.also you can use a vette motor and pcm,which did not have an egr :cheers:
Old Dec 26, 2002 | 10:33 PM
70 LS1's Avatar
70 LS1
Removing the EGR will definately set a code, but it will not negatively affect performance. I took it off my 99 engine and have had no problems.
Old Dec 27, 2002 | 02:51 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: EGR Removal? (70 LS1)
no C5 LS1 or LS6 1997 -2003 has ever had an EGR system.
Old Dec 27, 2002 | 06:56 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Default Re: EGR Removal? (kewlbrz)
It does if it came out of a Z-28! I needed(wanted) the forward location for the transmission. :rolleyes:
To EGR Removal?
