Rear Lower control arm nut removal
Old Dec 31, 2021 | 04:51 PM
Jeff Thompson's Avatar
Jeff Thompson
Default Rear Lower control arm nut removal
I feel dumb asking but I have wasted a lot of time tring to make something to get in the small space between the axle and 7 mm bolt to allow me to get the lower control arm bushing nut off.. It just spins and I cut down the few 7 mm Allen keys I had with no success.
anybody have a solution for this? I was even to the point of thinking about removing entire control arm but I still don’t think it will make a difference as the distance from top of bolt to axel housing(correct name?) would still remain the same.
took a pick of bolt. My project is wheel bearing replacement.. Yes I’ve been searching the forum but can’t find my solution.
any help would be greatly appreciated.. going out to get more 7 mm Allen keys to grind..
thanks
jeff
Old Dec 31, 2021 | 05:10 PM
ThomasR's Avatar
ThomasR
Remove the big axle nut and use and hammer and punch to free the axle splines from the hub. You should be able to compress the axle half shaft.
Old Dec 31, 2021 | 07:05 PM
lionelhutz's Avatar
lionelhutz
Put your floor jack under it and a ratchet strap from the jack over the spindle and then jack the jack and wedge the bolt into the hole so it'll quit turning.
Old Dec 31, 2021 | 07:15 PM
Jeff Thompson
Two excellent ideas. I will get back at it tommorrow.. thank you for taking the time to respond and help..
Old Jan 2, 2022 | 08:54 PM
Jeff Thompson
I actually did your technique and it worked out great. Thanks for your help!! If you ever get to south Jersey area you gotta let me buy you a beer or 10!!!
To Rear Lower control arm nut removal
