PN# for 2002 Z06 driver side fuel level sensor
Old Jan 1, 2022 | 06:16 PM
J-Rod's Avatar
J-Rod
Default PN# for 2002 Z06 driver side fuel level sensor
I was re-installing my fuel pump and one of the wires broke on the fuel level sensor at the sensor. I was looking around and most sources show the pn# as discontinued. So what I have been able to find is:
10333749 (AC Delco SK1318) superseded by 19418850 superseded by 88899034
10333749 was available in the aftermarket from NTK as FD0025 (its unavailable).
88899034 may be available I have found one online parts house which lists it in stock. I know with GM in many cases the same sensor can be found in other vehicles. I just wanted to see if anyone knew of a good and readily available part number that would interchange with the fuel level sensor.
Old Jan 1, 2022 | 07:42 PM
feeder82's Avatar
feeder82
Rockauto lists what you need but it's out of stock.
Old Jan 2, 2022 | 03:57 PM
J-Rod's Avatar
J-Rod
Correct. Its out of stock with most of the part stores I have checked with, hence the question.
Old Jan 2, 2022 | 06:07 PM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
Try searching the parts numbers on ebay. I've had a lot of luck getting genuine parts from there, new and in factory packaging. Their "does this fit your car" thing is dubious at best, but if you have the part number that you know for a fact is correct you should be good to go.
Old Jan 4, 2022 | 02:06 PM
J-Rod's Avatar
J-Rod
What I have found yesterday is that GM considers 19418850 the current PN#. I have found one at a "local" dealer (1 hr drive) for $172.00.
To PN# for 2002 Z06 driver side fuel level sensor
