heater and A/C not working
Old Jan 3, 2022 | 03:46 PM
lmallia's Avatar
lmallia
7th Gear
Default heater and A/C not working
I have a 2003 vette and the heater and ac do not work. What is puzzling to me, is when I turn either of them on, absolutely nothing happens. I do not get anything out of the vents. Any ideas would be greatly appreciated.
Old Jan 3, 2022 | 05:41 PM
1999corvettels1's Avatar
1999corvettels1
Sounds like blower motor is not spinning.
Might be a fuse to check, but I’ll let someone else who knows tell where to check for it if there is one.
Old Jan 3, 2022 | 10:18 PM
ncali's Avatar
ncali
I dont know why but every time I disconnect the battery on my 2000, the same thin happens with my ac/heater. The blower will not work.
I then hook up my tech 2 and run the blower motor using the tech 2 controls and it works again until I disconnect power.
See if you can find someone with a tech 2 and try running the ac /blower using its controls
Old Jan 8, 2022 | 09:14 PM
RandolphB's Avatar
RandolphB
Sounds like the heater/ a/c control is bad. It turns everything on and off.
To heater and A/C not working
