No crank one click issue?
Everything electrical with a C5 requires a battery with OEM functionality, otherwise, things get random. Hopefully you just need a new battery, if anything. but in any event, it should be tested to make sure it is correct to the required circuit function.
Since the radio doesn't work, the radio power would be the first thing to check, I have read that , since these cars are computer designed down to the half penny, connecting to other than one of two correct power takeoffs can cause problems.
If you just bought the car, I would suspect the radio install created a problem , if you have been running without problems , it is probably an easier repair, worn part mechanical only.
if it is a computer problem, the deal is that the alternator puts out a specific voltage range, you go outside of the window and the computer can't cope and throws a fit. With the power demands of an aftermarket radio, the usage often needs a more powerful alternator, but any out of compliance power delivery to the computer will screw things up. This commonly happens with guys just trying to replace a worn alternator, they get one that fits via fitment charts at the store , but it doesn't replicate the electrical output of the original part exactly, so , and it might take awhile, they have problems. This is why the original part is often rebuilt and never thrown away, the replacement alternators generally throw more power and after a while, just confuse things. The non OEM alternator doesn't fry the computer, it will work again if held to original design specs.
IF you have a non stock alternator , check to make sure it is within the specs, not over. Of course, it is a system , so as mentioned before, the battery function is critical.
It could be that with the disconnected battery, the computer reset and everything went to normal. In time a non stock electrical signal hit the computer, and you get random results ever after, but without the happy ending.
The other suspected starting problems are fairly well established here.
Behind the ignition key lock are the contacts for the starter circuit. The contact pads get fouled over time from electrical arcing, and cause intermittent connections. These contacts can be filed clean to renew function, very much like antique ignition points. I just bought a new part, rather than keep cleaning the old contacts, because of the labor accessing the thing.
The starters are sometimes reached with a broomstick and struck to get the rotor off of a worn spot, but I have never needed to strike a starter to figure out if it needed to be replaced. Some report that header heat melts the starter wires.
I hope this provided some food for thought, and the problem is easily fixed. With electrical, it could be as simple as a bad ground, to , well, there doesn't seem to be any limit .
