1999 C5 Steering Sensor
Old Jan 3, 2022 | 07:47 PM
C5fourme's Avatar
C5fourme
Cruising
Default 1999 C5 Steering Sensor
Looking for someone who can take my used 1999 C5 Steering Sensor and "Center It" before installation. Willing to pay for your service. Thanks
Old Jan 3, 2022 | 07:50 PM
KOZ's Avatar
KOZ
Count the total turns and divide by 2
Old Jan 4, 2022 | 01:17 PM
C5fourme's Avatar
C5fourme
Cruising
Not quite that easy. But thanks
Old Jan 4, 2022 | 07:29 PM
SilverC54me's Avatar
SilverC54me
This would have to be done on your car with a Tech2.
Where are you located?
Gary
Old Jan 5, 2022 | 11:30 AM
C5fourme's Avatar
C5fourme
Cruising
VA. I have ssen someone stating they did it with a Ohm meter before installation. Thanks
Old Jan 5, 2022 | 07:41 PM
KOZ's Avatar
KOZ
it is that easy. it has a total resistance from stop to stop. it expects to be installed in the center position
Old Jan 5, 2022 | 08:02 PM
lionelhutz's Avatar
lionelhutz
Plug it in without installing it on the column. Turn the key on. Turn it until you measure about 2.5V on the light blue wire.
If you want to double check your work, turn it each way until you find the minimum and maximum voltage readings. Then, figure out the voltage half way between those and set it to that voltage.
Old Jan 6, 2022 | 10:10 AM
C5fourme's Avatar
C5fourme
Cruising
I can do that no problem BUT as a senior citzen (70) i am no longer able to get under the dash to unplug it and plug used one in to test. Thats why I am willing to pay someone to do it for me. But thanks !!
Old Jan 6, 2022 | 10:00 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
You should state where you live. Maybe someone near you would be willing help..
Old Jan 7, 2022 | 05:58 AM
oelarse's Avatar
oelarse
Here is some good info on the installation
and here
To 1999 C5 Steering Sensor
