New Radiator Procedure + A Tip
1) Got a free gallon of DeWitts Performance Coolant with the radiator. This stuff gtg with the C5? Says it meets GM specs, so I imagine so, but wanted to check.
2) Is there a burp procedure for the C5 more than whats listed for a change here: C5 Radiator Drain and Refill instructions. (iammoon.com)
Tip:
The Mishimoto Performance silicone lower radiator hose WILL NOT fit on the Dewitts radiator, no matter how much swearing, lube, or twisting you attempt. Just a no go. I ended up purchasing a Gates stock rubber hose. Upper radiator hose from Mishimoto is gtg.
Tip:
Outside of the dreaded #7 Spark plug/wire removal and install, the project has gone smoothly until now when I need to attach the new hoses onto the new radiator. For the life of me, I can’t get the lower Mishimoto silicone hose to fit over the Dewitt’s aluminum radiator connector. I got the upper Mishimoto hose connected but still think I need to have it seated further up the aluminum tube over the second nipple. Below are a few pics. Do these look correct? Should the upper hose that connects to the water pump pe pressed further on or will the clamp be too close to the drive belts? The lower connection into the T-stat should probably be further pushed on as well correct? The smaller, auxiliary Mishimoto silicone hoses have worked fine with no install issues, just having issues installing the larger upper and lower radiator hoses.
I’m also not happy with the quality of the supplied Mishimoto stainless steel clamps so I’m going to swap those out for some Master Pro spring clamps before I complete the installation. I may also grab a new OEM rubber lower hose if I can’t get the Mishimoto Silicone hose any tighter. I’ve tried using a small amount of dish soap to help push it on but so far, it’s not working.
As to the system flush, since my original coolant is drained and will be disposed of, I plan to flush the system with 4 gallons of distilled water and run the car until the fans come on, drain, and then fill with the Prestone GM Dexcool mix. I will then check the surge tank over the next week to cap off if necessary. Lastly, I decided to also install a new surge tank cap just to be safe since the original one is close to 20 years old.
Upper & Lower Water Pump /T-Stat Connections
Upper Radiator Connection
Lower T-Stat Connection
Upper Water Pump Connection
Proper flush.
Fill with proper mixture of distilled water and Justice Bros. "Protector" and "Super Radiator Cooler".
2 bottles of each per car.
No antifreeze !!
Antifreeze is not a good coolant.
