P0131 + P0171 + P0175 Codes...
My car is a '04 LS6 Z06, with full exhaust (long tubes, h-pipe and no cats), heads, cam and tune.
I took it to the detail shop to have it cleaned, but when I picked it up, I noticed it was running a little rough. Taking off from a dead stop was fine, but about mid gear, it seemed to stutter, however, if I rolled into the throttle, it seem to clean up. The drive is about 15 minutes from my house and about 5 or so miles before I got home, it started running pretty rough.. wouldn't hardly idle and then it threw a P0131 code.
I called a friend and he suggested I pull the MAF and clean it with a specific MAF cleaner, I did, as well as cleared the code, then took it for a short drive. It seemed to fix the problem at first.. Then, it started running the exact same way again, and again.. The light came back on the dash (CEL)...
I again, pulled the codes and now, not only did it have the P0131, but also had P0171 and PO175 codes.
He's now suggesting that I replace the MAF and both upstream O2 sensors (the down streams are plugged - no cats)
Before spend ~$250.00 on parts... I'd like to get a second (or third) opinion(s)?
P0131 - O2 Sensor Low Voltage Bank 1
P0171 - Fuel Trim System Lean Bank 1
P0175 - Fuel Trim System Rich Bank 2
** The car has always had a strong rich fuel smell, I "assumed" it was due to the tune and cam? The cam has a pretty heavy chop to it..
The car is in the air, on my quick jack, but I haven't pulled the O2s to look at them yet, let me know if I should post some pics?
Any advice would be greatly appreciated!
and no... I'll clean parts, but spending $250 on parts that "might" fix it.. Is not something I want to do..
https://youtu.be/5WnM_NsOtd8
I'm headed to the garage now, to see what i can figure out - if I get stumped..... I'll let you know!
I was just about to ask you... # 6 fuse under the hood is "Fog Lamps' and in the footwell, # 6 is "PK T/ LMP".. This is the fuse for the 02 sensor? ** Remember, I'm working on a 2004 Z06
I was just about to ask you... # 6 fuse under the hood is "Fog Lamps' and in the footwell, # 6 is "PK T/ LMP".. This is the fuse for the 02 sensor? ** Remember, I'm working on a 2004 Z06[/QUOTE
Sorry 15 !!..shouldn’t try to memorize these !!
