98 headlight gear replacement
Old Jan 16, 2022 | 08:03 AM
c4gone's Avatar
c4gone
Default 98 headlight gear replacement
I've seen posts of changing the gears and needing to clamp down the housing but I've also read that the early c5s such as mine with the 3 bolts don't need to be clamped down, just bolt and go. Is this true?
Old Jan 16, 2022 | 10:16 AM
Johnny Hardcore's Avatar
Johnny Hardcore
That is correct. The earlier models 97,98, some 99s have the heavier duty aluminum casing that has 3 screws holding it together. The later models came with plastic housing that is epoxied together.
My 99 coupe came with the later model housing that is glued.
Here is a good write up for you from Rodney Dickman.
http://rodneydickman.com/product_inf...products_id=92
Old Jan 16, 2022 | 02:00 PM
jdmvette's Avatar
jdmvette
Night Owl for life
If you find that you need a new motor, these are only $54 each
https://www.ebay.com/itm/36297840954...3ABFBMzNnIw8xf
Old Jan 16, 2022 | 03:34 PM
c4gone's Avatar
c4gone
I got mine from him.
Also one issue I'm having is I CANNOT lift the light. No matter how much I twist the thing, it will not raise
Old Jan 16, 2022 | 11:27 PM
Johnny Hardcore
Here you go....
https://www.corvetteforum.com/forums...ease-help.html
To 98 headlight gear replacement
