Not starting another which oil is best thread please….looking for real world “I have done this” comments please…
In attempting to reduce the different types of oils on my garage shelf I’m curious if anyone has ran M1 0-40 in their C5…. Currently using M1 10-30 in my 01 base with no issues but I run the 0-40 in our 3 BMWs with no issues either. So I could keep the same weight synth oil for all those cars by switching over the C5.
I live in Virginia so it’s a moderately mild climate and it’s mainly a fair weather weekend car.
I don’t believe I will see much difference between the two weights but I was curious if anyone had ran the 0-40 for any length of time….. thanks
I run 10-W40 on my track driven street car without issue. Just know that on cold days (like below 40°F) the oil will take longer to get everywhere. I let it sit and idle for a min before trying to move. You should be good in your climate though.
I've run M1 in my LS7 engined C5 since 2005. I live in Michigan (read: COLD!!). Even when cold, 0w-40 will flow to critical bearings and other surfaces as quick as 5w-30, with the protection at high temp of the thicker 40 weight. 10w-40 is more viscous when cold that 0w-40.....
Just a thought…some of the foreign brands are really picky about their oil. My wife’s Audi doesn’t even have a dipstick, so you have to add a few ounces at a time, wait a couple of minutes, then turn on the key so the computer will tell you if the level is within spec!
In addition, the owners manual calls for a very specific composition that my other oil did not contain. As I recall it had something to do with a minimum grade VW specification. So, you may be OK on weight, but I would check out both factors.
What kind of oil temps are you seeing, and at what temps. M1 5w-30 I'm seeing 200-210 at highway speeds.70-90 ambient temps. No oil coolers. Thanks.
I have liquid/liquid oil cooler & aftermarket radiator. Oil temp 190-200 daily driving, 200-218 autocross/ road track, same oil pressure as 5-30. I believe the 0-40 has higher zinc and phosphorous, like the old M1 when my car was built in 99. I figured quicker lubrication when cold and thicker when hot.
Oil weight is the first number 0.
They add a thickening agent that reacts with heat. The hotter it gets, the thicker it gets to the rated thickness.
over time, this thickener loses it’s effectiveness, and ghe oil gets thinner. The reason the oil turns black is the contaminants in the oil, which adds viscosity to a point.
just gollow mfg’s oil change recommendations to prevent thinnrr oil and sludge deposits.
fo a simple test.
just before hour next oil change, write or make a note on your phone, your oil pressure.
then change the oil snd gilter, and note hour new oil pressure. They dhould be different.
In Phoenix, after months of 117 degree days,
i can pick up 10 psi with an oil change.
I was referring to you trying to use the same oil for both cars, including the BMW. The C5 is easy, Mobil 1 5W-30. It’s the BMW that may have specific ingredients or standard.
The BMW oil of the same weight may be fine for the Vette, but not necessarily the other way around. The owners manual for each car should have all the specs in addition to the viscosity.
fo a simple test.
That is incorrect. The second number is the weight (30, 40, 50). The first number in "W" oils is an indicator of oil friction or resistance in cold temperatures from 23°F down to -31°F during what is called a "Cold Crank Simulator Test". The lower numbers are better flowing or less resistant in the cold (0, 5, etc). Whether it is a 0W-30 or 5W-30 or 10W-30 it is still a 30 weight oil. However the 10W-30 will have more resistance in the cold than the 0W-30 oil will. Since race cars dont typically run in the cold racing oil is usually just straight 40 or 50 weight with no "W" indicator.
This is correct that BMW usually has some strict requirements for shear stability in their LL01 or LL04 requirements, but most good modern synthetics will have no problem passing requirements for multiple platforms. The requirements should be listed on the bottle.
fo a simple test.
Not to start trouble, but I believe there is no oil that thickens as it warms. AFAIK, ALL oils thin out as they warm. If oil thickened as it was heated, everyone would change their oil when the engine, and oil, are cold, not hot!! I'm 99% certain that the additives help control the rate at which the oil thins as heat is introduced. My .02
Motor oil gets thinner as it's heated, but to prevent it from getting too thin at higher temperatures, additives (viscosity modifiers) are used so that it behaves like a thicker grade oil at higher temps. ... The lower the first number, the better the oil will pump and flow at cold startups.
I found an article that explains how viscosity is altered. Just for fun…
” In the mid-1950s, oil industry chemists developed an oil additive called a Viscosity Index Improver (VII). Viscosity Index (VI) is a description of the rate at which oil will change viscosity as temperature changes, all oils thicken in viscosity as temperature drops and thin in viscosity as temperature rises, good quality virgin mineral oil has a VI of around 95 to 100. The newly developed Viscosity Index Improver (VII) additive changed the rate at which oil thickened as temperature dropped and thinned as temperature rose. An oil modified with a Viscosity Index Improver still thickens as temperature drops, but it doesn’t thicken as much as a non-modified oil. Nor does it thin out as much as the temperature rises.
A Viscosity Index Improver (VII) additive is an organic chain molecule which is bundled up like a ball of spaghetti and dissolves in the oil. When cold the VII molecule shrinks and the oil has less resistance flowing passed – less resistance to flow, lower viscosity oil. When hot, the VII molecule swells and produces higher resistance to the oil flowing passed, the oil has still thinned out due to the temperature rise but now it has a higher viscosity than if the VII was not there.“
Check on a bottle and see if mobil 1 still has a 1-800 oil advice phone line. I got some good information when I called, and the more information, or more correctly, factual information, since this is an internet oil discussion, the better the decision.
They even gave me advice about oil for my record player, after checking with the lab, saying that a zero viscosity would offer no benefits over the 5- 30 I run in the main bearing, until zero degrees.
When I asked about fuel saving oil, I learned what should have been obvious to me, that modern valve trains are designed for ultra fuel efficiency and need a very different and specific oil than the other stuff on the shelf. So I suppose the old crap about not mixing oil has finally come true.
