Dilusi Brake (Stage III) Problem
Old Dec 28, 2002 | 05:45 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
Default Dilusi Brake (Stage III) Problem
I have a problem with a rubbing noise on slow sharp turns, both directions. Any ideas?
Old Dec 28, 2002 | 06:42 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Dilusi Brake (Stage III) Problem (Sully C5)
Sounds like you brake lines are binding. I would take the wheels off and turn the steering full circle both directions and check tension.
Old Dec 28, 2002 | 08:15 PM
Sully C5's Avatar
Sully C5
Default Re: Dilusi Brake (C5-VERT)
Thanks! I'll give it a shot.
Old Dec 29, 2002 | 08:43 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Sounds like not enough of the lower ball joint housing was ground off when the system was installed. The Rotors are so thick that part of the lower ball joint area needs to be ground off to provide clearance for the rotor when it is straight and turned left and right. Check the inside of the front rotors to see if the lower ball joint casing is rubbing the rotor. If so, remove the rotor and grind off whatever material is needed to provide clearance. :yesnod: Re install, and you are good to go. ;)
vetterdstr :cheers:
Old Dec 29, 2002 | 08:45 AM
Sully C5's Avatar
Sully C5
Default Re: Dilusi Brake (vetterdstr)
I was not aware of that. Thanks!!
Old Dec 29, 2002 | 08:47 AM
vetterdstr's Avatar
vetterdstr
Default Re: Dilusi Brake (Sully C5)
yep, these are the things you learn when you do the install yourself. ;)
I am glad I can help you out with your problem. :)
vetterdstr :cheers:
To Dilusi Brake (Stage III) Problem
