no fuel regulator..
Old Feb 15, 2022 | 09:37 AM
clutch1's Avatar
clutch1
Default no fuel regulator..
Just got 99, frc, Ls1...Has after market fuel rails..NO FUEL PRESSURE REGULATOR.....hAS ONE FUEL LINE........................Question, do I need a regulator?..Should I put on on it?............Thanks......John.
Old Feb 15, 2022 | 10:11 AM
helga203's Avatar
helga203
you dont need one, as long as ur fuel pressure dosent drop to much. couple of buddies have it this way. psi start around 58 to 60. but if PSI starts failing at hight rpm then ur going to haft to get a stronger fuel. JME. and going with a reguater ur head of the game it u go F/I.
a kit is going to cost u around a 1k, but if u know how to do it u'll save bucks.
Old Feb 15, 2022 | 11:14 AM
MetalMan2's Avatar
MetalMan2
Usually only one fuel line in the engine bay means the regulator is built into the the fuel filter. So with any luck you'll see 2 lines going into the filter and one coming out (3 total). Check it out.
Old Feb 16, 2022 | 01:40 PM
clutch1's Avatar
clutch1
yes your right, thanks..............
To no fuel regulator..
