Benefits to catch can?
Old Feb 21, 2022 | 08:32 PM
c4gone's Avatar
c4gone
Default Benefits to catch can?
I'm on my 4th vette and know alittle about this and that but not about a catch can. The car is a 98 with 189k and mainly all stock and will mainly stay that way other than a cold air but can y'all educate me more on a catch can? The prices seem reasonable and quick to install but i don't know alot about them. Everything I read is "pro" and no cons, so that's why I thought I'd ask
Old Feb 21, 2022 | 08:37 PM
vettedays's Avatar
vettedays
at 189k miles probably won’t matter much at this point. If you decide to pull the intake and heads and clean things up, id install a can then.
Old Feb 22, 2022 | 02:52 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I just posted this in another thread:
I once asked Evil-Twin about catch cans in a private message back in 2008 and he responded back to me with this
I quote: " Mike, you may not like my answer... but most of these extra added mods are someone’s cash cow, or someone’s self serving statement that what they have done or bought into is earth shaking.Truth is, we spent two years developing this car before launch in 1997... with thousands of hours of testing we also increased the benchmark in testing which formerly was 100,000 miles... every other manufacturer used the 100,000 mile testing bench mark... we tested this LS1/6 to 200,000 miles, which was unheard of... we tested the actual engine, clearances, oil spec a,d oil life monitoring system.. we did this on ever test mule with no issues.. we ran this cars full out for 800 hours, and 200,000 miles under all conditions.. when we tore these mules down, we found that all critical dimensions were still in spec.. I get Pm's and emails from lots of members with 200,000 and even some with 300,000 miles on their C5, without issues.... most of the problems with LS1/6 engines are from people running too cold of engine. using regular gas, using non certified oil, and most of all by these types of modifications... GM spent millions in the development of this car...all of these get rich quick for the developer are for the benefit of the retailer. there are some benefits to be had in tire pressure tuning, trying to keep the engine in the sweet spot.... many people think that what their grandfather did in 1960 applied to this engine, which of course it does not... lots of people on the Corvette forum want to be a hero, want to tel people that they have found a magic pill, this throttle body bypass is a typical example... it does absolutely nothing but run the risk of throttle body freeze and potential to cause a stuck open throttle.. I’ve invested 50,000 dollars in my education and GM has invested over 1 million dollars in my ongoing education. DO you really think some back yard mechanic can design and test, to test to failure studies and have the millions of dollars in test equipment that GM has given us to develop this car...
I don’t post in open forum anymore because the forum has slipped so far down the Do it yourself ladder, that I would be battling all day... I read about these guys that are running their oil at `150 degrees F for long periods of time.. running regular gas and causing engine knock.. even thought knock sensor will react. you can have the knock sensors working everyday.. I could go on and on.. the PCV valve is not worth changing... and most catch cans are the product of those using an Oiled air induction system..You cannot trust any retailer or anyone who says their product or modification has made quantum leap. The mentality found here is far from being constructive.... and its only gotten worse. getting a custom tune is a good thing if the tuner knows what he is doing, you can gain hp with mods, but run the risk of internal damage.. the front end suspension on a C5 is designed for this engine weight and not for an increase of 100 lbs of super charger and components or magnacharger, the reason this C5 is so good price wise is because it was designed to be not over engineered. This kept the cast down.. when we stared this car we had a budget and a target market . its a credit to the design engineers for making this car and the project managers for keeping it in budget.. designing a front suspension that would carry the extra weight of a super charger and inter cooler would have added weight and cost... I was personally turned down for a mod that would cost 70 cent to each C5, I Have 7 designs in every C5 on the planet, and one of them would have cost and extra 70 cents a car, but it was over our budget so I got a no... this is typical of every project of the C5 platform.. Some of the components are cheap, but thank god they are because if we made every component as good as we could very few people would be able to afford this car... I see people bitching about poor design all the time.. it just goes to show that no one knows what it takes to deliver a car within budget.
Sorry for the long winded pm
regards
Bill aka ET"
RIP Bill
Your friend, Mike
Old Feb 22, 2022 | 03:26 PM
vettedays's Avatar
vettedays
No offense to Bill, but this was my “catch” after 53 miles of driving. This should not be fed back into an intake manifold. Imagine what a 100k mile car looks like. I don’t think the c5 designers ever really figured out the pcv system on these cars just from the mere fact there was about 5 different design changes.
Old Feb 22, 2022 | 05:04 PM
Justin Raney's Avatar
Justin Raney
Ok i see so it'd be full at 1000-1500 miles. This is a good idea im looking into the same thing as original poster.
Old Feb 22, 2022 | 05:16 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
regards
Bill aka ET"
RIP Bill
Your friend, Mike
Great info Mike...thanks for posting...he is still giving help from the grave
...RIP Billy Boy
Old Feb 22, 2022 | 06:32 PM
Mike98SilVert
I did not see eye to eye with Bill on a lot of things but Bill was a genius when it came to cars. He really knew the C5 Corvette. I have had arguments with Bill but respected him whether I thought he was right or wrong, usually right when it came to engineering. Ed aka as Patches was another great engineering mind.
Old Feb 22, 2022 | 06:41 PM
1Hotrodz's Avatar
1Hotrodz
So then, the question begging to be asked is: What was that rejected 70 cent Mod ? Anyone know?
Old Feb 22, 2022 | 06:58 PM
vettedays's Avatar
vettedays
Rip billy. But Billy always argued with everyone on this forum. Once, he was arguing with me via text message on the fitment of baer brakes saying they wouldn’t fit my car. Billy didn’t know I was literally standing in baer brakes in Phx and they were reading his texts and disagreeing with him. Baer knows their parts better than Billy. He was such a character. Rip Billy aka EVIL TWIN.
Old Feb 22, 2022 | 08:47 PM
Mike98SilVert
I did install an Elite Catch Can on my '99 despite Bill's recommendation. Had it on my '99 for 8 years and sold the car with it. I checked it often and never collected any significant amount of oil. I emptied it twice, the second time was just before the new owner took ownership. I could have sopped it up with a section of Bounty. My engine was stock with Kooks long tube headers Magnaflow exhaust Blackwing (oiled filter which was another of Bill's pet peeves), never traced or drag raced the car. Modified LS engines benefit from catch cans. I liked the quality and look of the Elite Engineering product. They made some nice products.
Old Feb 22, 2022 | 08:59 PM
vettedays's Avatar
vettedays
Sounds like you had it installed incorrectly. Elite is fine. But on the cheaper side. No engine builders use elite. It’s like an eBay product.
Old Feb 22, 2022 | 09:46 PM
Mike98SilVert
I had it installed correctly but thanks for your presumption.
I don't wind out each shift at red line but drive like a responsible adult in my daily commute. If I did drive like that for 10-11K miles per year I could see having to empty a catch can frequently especially on a modified engine.
Old Feb 22, 2022 | 10:02 PM
_zebra's Avatar
_zebra
^^ this right here's what i was about to say.
the effectiveness & benefits of a catch can it all depend on how the car's driven. a stock car that's driven with civility all the time will be wasting money. i've got a big cam & big blower that, when driven smoothly around town & not wound out, collects very little oil... but a weekend at a road course could easily collect a few ounces.
Old Feb 22, 2022 | 10:15 PM
vettedays's Avatar
vettedays
Since when is driving like a “responsible adult” mean you shift like a grandma!
Old Feb 22, 2022 | 10:19 PM
vettedays's Avatar
vettedays
[QUOTE=_zebra;1604773592
a stock car that's driven with civility all the time will be wasting money.[/QUOTE]
I respectfully disagree.
Old Feb 22, 2022 | 10:24 PM
Mike98SilVert
That's it exactly.
Old Feb 22, 2022 | 10:46 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Bill and Ed were 2 of the greatest and most helpful assets on this forum...Ed is still alive... Ed had the greatest write-up and pics that I have ever seen...
To Benefits to catch can?
Old Feb 22, 2022 | 11:03 PM
_zebra's Avatar
_zebra
why for? i've had my catch can on for over a decade (8yrs of which was with a blower on a stock engine - the rest with a built top end), and almost 40,000 miles of driving across the country or just putting around town - mostly in vacuum - have resulted in oil changes that only condensed a few mL of oil into the can... because
checking the can after a track weekend (or a few "energetic" drives through the local mountains), however, has resulted in ounces of oil in the can.
Old Feb 22, 2022 | 11:10 PM
ariZona06's Avatar
ariZona06
Ah, the great catch can debate. A MUST for every automotive forum. Entertaining and yet informative. My own personal experience is it's darn near a necessity on today's direct injection cars, definitely needed for a track vehicle and probably a "hey why not?" for a street performance car. I've got one on my C5 track car and I also get anywhere from 1 to 2 ounces of oily substance after a track day. My can is from Mike Norris. Not sure if he's related to Chuck but it does kick ***!
pjdbm's Avatar
pjdbm
My basically stock LS1 with 65k has a catch can, I empty it twice a year and it is a weekend car with no racing.
I originally added a catch can when I swapped my LS1 intake to an LS6. When I saw the amount of oil that was in the old LS1 intake, I decided a catch can will be added.
Last year when I cleaned my throttle body I took a peek inside the intake and it was clean.
Seeing is believing, I happy happy with my Moroso catch can
