LS-1 into a C-4? Help?
Old Dec 29, 2002 | 06:57 PM
MR.Z06's Avatar
MR.Z06
Default LS-1 into a C-4? Help?
Just bought an LS-1 out of a 97 Vette, everyone is calling me crazy, but I think I want to put it into the 85 Vette that I allready have that is - an engine.
Tips, tricks, suggestions???
Old Dec 29, 2002 | 07:24 PM
Austrian Vette's Avatar
Austrian Vette
Default Re: LS-1 into a C-4? Help? (SoSlo)
If you find a way, let us know
Old Dec 29, 2002 | 08:03 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
most defintely have better luck posting this on LS1tech.com :cheers:
Old Dec 29, 2002 | 08:28 PM
RCswish's Avatar
RCswish
Default Re: LS-1 into a C-4? Help? (Mean Green 2000)
I'm not sure I've ever seen this done. You may have been better off with an LT1 swap.
Old Dec 29, 2002 | 09:29 PM
Bill Reid's Avatar
Bill Reid
Do an archive search on TracerX... he is a forum member who frequents (or at least used to) the C4 Sections and has done it with very encouraging results :)
:cheers:
[Modified by billreid1@***.net, 7:31 PM 12/29/2002]
Old Dec 29, 2002 | 09:32 PM
SFVetteman's Avatar
SFVetteman
With time and money almost anything can be done. With time and a lot less money you could have a modified LT-1 that would be equal to or better than a stock LS1.
Old Dec 30, 2002 | 09:59 AM
Redvette_22's Avatar
Redvette_22
SoSlo, I saw this done with one car that ran at Englishtown and the results were pretty good. If I remember correctly, the only real problem with the install was the headers. HOWEVER, the PCM and electronics drove the guy crazy for a year, and he finally gave up. Good luck with your endeavor.
Old Dec 30, 2002 | 10:29 AM
Chris@SD's Avatar
Chris@SD
As Bill said, page TracerX. He is a friend of mine with a pretty successful install of an LS1 in a C4. :) :) Headers are not really a problem. I believe that the F-body headers fit well.
The only thing I will suggest is, use an F-body LS1. The C5 LS1 is going to give you problems when it comes to fly by wire and BCM, CCM stuff.
Good Luck,
Old Dec 30, 2002 | 10:44 AM
RHILL's Avatar
RHILL
Default Re: LS-1 into a C-4? Help? (Chris@SpeedDemon)
You could most likely go out and buy a C5 cheaper then putting a LS1 in a C4. :cheers: I think a ZR1 engine in a C4 is a far better choice :thumbs:
To LS-1 into a C-4? Help?
