B2578 b2583
Old Feb 27, 2022 | 04:18 PM
Justin Raney's Avatar
Justin Raney
Default B2578 b2583
Is it possible for led zevo 4057 turn signals with no hyperflash harness to set off these codes? I had a bad led that worked but would intermittent stop flashing for 10 seconds then start flashing again but got those replaced with same bulbs and they function normally just hyperflash.
B2578 right front turn signal monitor circuit
B2583 left front run signal monitor circuit
Old Feb 27, 2022 | 05:18 PM
jcgunn's Avatar
jcgunn
Yes, that is exactly the problem.
Old Feb 27, 2022 | 05:37 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
The hyperflash harness installs in like 20 minutes tops. Worth doing. That is what those codes are from.
Old Feb 27, 2022 | 07:45 PM
Justin Raney
theres the hi4 relay hyperflash and the 38$ hyperflash harness on ebay that would solve these codes?
Old Feb 27, 2022 | 07:46 PM
Stingroo's Avatar
Stingroo
The Hi4 relay is different. That one just keeps your low beams turned on when the high beams are on. The hyperflash relay is what you want.
Old Feb 27, 2022 | 08:15 PM
Justin Raney
No i meant the original hyperflash harness is from corvette envy that makes the hi-4 relay. Theres a different place on ebay that sells them for 38$ the wiring is a different color.
Old Feb 28, 2022 | 11:29 PM
Moved to C5 Tech.
To B2578 b2583
