How does a shift light work?
Old Dec 30, 2002 | 11:42 AM
WildKarrde's Avatar
WildKarrde
From: My tolerance for stupidity is at an all time low.
Default How does a shift light work?
Can someone explain how a shift light does what it does? How does it connect to the engine? How do you set it to light at a certain RPM? Is it adjustable or do you order it set at a particular point? If there are different ways to get it to work, please explain the differences.
Thank you. :seeya
Old Dec 30, 2002 | 03:22 PM
Patches's Avatar
Patches
Default Re: How does a shift light work? (WildKarrde)
It connects to the tach wire in the harness under the dash along with switched power and ground wires. If you look at the Raptor Shift Light below, you can see the exposed circuit board. The dip switches are for setting the number of cylinders in the engine. There are two rotary switches for setting the shift rpm, one for rpm x 1000 and one for rpm x 100. These are set by the user and can be changed at will. When the engine hits the set rpm, the LED's are activated.
:cheers:
Old Dec 30, 2002 | 04:23 PM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
http://www.lgmotorsports.com/catalog...gnition&car=c5
that is a link to our "Sequential" shift light. It comes on at 1/2 of the selected rpms, and goes from Green to yellow, as you approach your selected redline. Then when you reach your selected redline, all of the lights flash on and off, till you shift.
Just like the F1 cars :yesnod:
thanks,
Lou G
To How does a shift light work?
