c5 engine
Old Mar 10, 2022 | 12:30 PM
Herm_32's Avatar
Herm_32
3rd Gear
Default c5 engine
So I have a 99 c5 that needs a new engine, I found one from a 01-04 would there need to be anything changed or would it just be a straight swap over?
Old Mar 10, 2022 | 12:55 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Realistically it will be a straight swap over.
The only thing of caution I can think of of the top of my head is your 99 should have the smaller 26lb fuel injectors. If you are swapping in a WHOLE engine, the newer engine may have 28lb injectors. If that is the case you will want to keep your original injectors to keep the tune happy.
Also if the replacement engine is whole you will get the better LS6 intake manifold.
Old Mar 10, 2022 | 12:57 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
It should be a pretty simple swap, but the new engine is slightly better. Enjoy your extra 5 HP!
Old Mar 11, 2022 | 12:42 PM
Moved to C5 Tech for further discussion.
To c5 engine
