Bad A/C compressor?
Old Mar 14, 2022 | 11:03 AM
G_Loc's Avatar
G_Loc
Default Bad A/C compressor?
A/C hasn't been cooling very well. Threw some gauges on it over the weekend at the low side was at 29 PSI and the high at 115 or so. Ambient temperature was ~80-85 and readings were taken at idle. Compressor clutch is engaging. I checked the manual and my specific scenario isn't mentioned in there. Does it sound like the compressor needs replacement?
Old Mar 14, 2022 | 11:54 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Sounds like low on refrigerant…high side should be over 200…I’d say take it to an AC shop and let them look for a leak…if you are low on refrigerant there is a leak…fix that if and then evacuate the system and then add the CORRECT amount of refrigerant !!
Old Mar 14, 2022 | 12:44 PM
VetteMed's Avatar
VetteMed
Agree with above. Pressures give some idea about charge status but an accurate weight of recovered refrigerant is your best bet to determine if the low pressures are due to a low charge vs a worn out compressor.
Old Mar 14, 2022 | 02:07 PM
G_Loc's Avatar
G_Loc
Thanks for the feedback. Hopefully it's just that. Time to find a competent A/C shop!
Old Mar 14, 2022 | 04:27 PM
feeder82's Avatar
feeder82
Here's a file on compressor replacement if you do it yourself. This is from forum member Rocco
File Type: pdf
To Bad A/C compressor?
