LS6 oil viscosity question. 20w50
Dave
That said, your bearing clearance should determine oil weight. I wouldnt use anything more than 40weight in a stock clearance bottom end. Especially it all it sees is street driving.
ThanksDave
Less viscosity improver's than a 5-30, or even a 15-50.
Just a thought...
There is a few petrochemical engineers that hang out here:
https://bobistheoilguy.com/forums/
Beware of unknown clowns.
I've spent many evenings on those boards (oil). Who would have thought...
ThanksDave
Why 20W50, own a lot of old diesels? Nothing else but big clearance race engines require that kind of oil.
As far as my opinion/experience using 15W50 for all the years I'm just basing this on what i have experienced/tried and documented throughout many years with this particular engine. When I was serious into racing I always was data logging and monitoring not only oil pressure and temp but also many other PIDS in relation to operating temps of fluids vs. performance, DA, etc.. I also always had my wideband integrated into my HPT logs so i had a pretty firm grasp of what was going on. Even though I do run a bit less capacity (I use a C6 oil pan) I've never seen a situation where the oil didn't return to the pan fast enough. That was actually my biggest concern but it proved to be a non issue.. The only thing on this engine I did not monitor were EGTs given it was a NA engine I didn't deem it necessary. I never did see any notable issues when going from 5w-30 to 15w-50 in my case. Full discloser I do rev this engine to 7k (T56 car) based on the cam/head setup and dyno sheet. Well I did, I brought it down to 6,800 in subsequent years just because I didn't want to be that hard on the valve springs. One day I'll pull the main/rod caps and see how everything looks but given the history this engine owes me nothing and I bet they still look like new.
20w50 is required for the engine/transmissions in my zero turn mower and that is about 9qts there. Add in the 6 qts for the C5 and that'd put me at exactly 3 five qt containers. Going from 15w-50 to 20w50 in my case would make no difference (as far as I can tell) so it makes sense to me to make the change. Most of my other cars require 5w30. Then I have my RV and it's generator, my portable generator, pressure washer, motorcycle, snow thrower, etc. I'm just trying to find oils that are within spec given their use case and make as many oils the same as I can.
It's either I'm going 20w50 from the 15w50 I've used for 15+ years or going back to 5w30 and dealing w/ the low hot idle oil pressure I've always seen in the LSx engines. I just don't want to stock a bunch of so many different oils. Years ago i did research on acceptable oil pressures for the LSx and I knew I was w/in spec running 5w30 but I just didn't like the low oil pressure. I certainly could not argue with the results I've had throughout the yeas using 15w-50. The engine always has exceeded expectations on the performance side of things. I put that engine through more than most would and it's never complained. Granted this particular engine has never been forced induction, just a little ole 11:1 NA engine but it has over a thousand passes on it with nothing more than the periodic valve spring change. Oddly upon checking spring rates after probably 600 passes the springs were still within spec! I'm probably thinking of .003 from my ford days as .0015-.0002 sounds about right to me. Been years since I've checked the clearances on an LSx motor.though.
And to the point of engineers recommending an oil, there is much more to recommending an oil for these than just viscosity.. Yes, it's a huge part of it but they will recommend viscosities for other reasons as well For example, a lower viscosity will improve fuel mileage and when trying to reach EPA goals the engineers may go w/a thinner oil as a slight expense to longevity so long as it keeps that longevity beyond a warranty period for example. I'm too lazy to look in my service manuals but I cannot find an ls1/6 viscosity chart on the internet anywhere. I wanted to see the temp vs. viscosity chart they provide for the LSx engine.
Dave
I too run 0W40, but I doubt it makes much difference 5W30 or 0W40. I just don't pay much attention to the idle oil pressure and then it doesn't bother me.
I run 0w40 or 5w40 in mine for a similar reason-- I require it in another car and it's nice and easy to just buy the same oil in 5 gal jugs.
I ran 20w-50 in my endurance boat race motors, which operated in ambient temps of 60*-105*. The tolerances were big enough that we went from build, to tune, to race. This was a 1100 hp gasoline supercharged BBC that ran flat out for 20-30 minutes per heat.
Now keeping in mind that the resistance on a boat hull is like driving a car uphill the whole race, even with raw water coolers the oil and engine temps were pushing the edge. The heat soak was incredible by the end of the race..
My engine needed, and was designed for, 50w oil to survive. I suppose it would be OK for a street car, but I don’t believe it is the best choice for a street car. As others have pointed out, rate of flow is an important element of heat transfer. A similar situation with coolant; if it passes through the radiator too quickly, it’s efficiency in transferring heat is diminished. So tolerances play a role in lubrication, but flow plays an important role in heat transfer. Both roles are key.
I’m not an engineer, and I highly recommend that no one takes my advice…lol
IIRC, .002-.0025"? .003" would be on the upper end of the scale.
