my new Corvette.
Hello friends, how are you? I'm telling you that my driver's side window goes down but doesn't go up. Visually everything is in order, cables and mechanisms. I put 12 V power directly to the motor and the window went up. then it means that the master window swicht is the problem.
Rgds Jose Alvear Z
my new Corvette.
Rgds Jose Alvear Z
There a wire harness that goes through the door to cabin maybe a wire came loose.
